Probleme "stylesheet"
bonjour a tous :)
je sais que ce sujet a déjà été posté mais pas de réponses convenables.
lorque je vais sur le chat nrj, et que je met l'option "rechercher", voila ce que ca m'affiche:
Server Error in '/' Application.
No stylesheet was loaded.
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.InvalidOperationException: No stylesheet was loaded.
Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.
Stack Trace:
[InvalidOperationException: No stylesheet was loaded.]
System.Xml.Xsl.XslTransform.Transform(XPathNavigator input, XsltArgumentList args, TextWriter output, XmlResolver resolver) +90
System.Xml.Xsl.XslTransform.Transform(IXPathNavigable input, XsltArgumentList args, TextWriter output, XmlResolver resolver) +45
System.Web.UI.WebControls.Xml.Render(HtmlTextWriter output) +1138307
System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter) +25
System.Web.UI.Control.RenderControl(HtmlTextWriter writer, ControlAdapter adapter) +121
System.Web.UI.Control.RenderControl(HtmlTextWriter writer) +22
System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) +199
System.Web.UI.Control.RenderChildren(HtmlTextWriter writer) +20
System.Web.UI.Page.Render(HtmlTextWriter writer) +26
System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +2558
svp j'aimerais bien résoudre ce probleme. merci bisous a tous. benji =)
Source Error:
Stack Trace:
bonjour kalamyti, je suis déjà sous mozilla firefox, et sa fait pareil que sous internet explorer :( en général je me débrouille pas trop mal en informatique, mais la j'avoue que je n'arrive pas a me débarrasser de ce problème :( bisou benji ;)
Bonsoir
Pour te rassurer je ne pense pas que ce probleme ne vient pas de toi... ou peut etre de ton navigateur.
Change de navigateur internet prend par exemple Mozilla Firefox.
