Problème d'instal
Ce week end, j'ai voulu installer un cours de langue sur mon ordi (vista - firefox).... impossible d'installer : message d'erreur
%% PLEASE DO NOT MODIFY OR DELETE THIS FILE! %%
%% This file contains information about the installation of an application. %%
%% It will be used to automatically remove all application components from your computer if you choose to do so. %%
NOTE: Beginning of the bootstrapper section
*** ERROR: Unable to create a directory named 'C:'
*** DURING THIS ACTION: CreateDir: "C:"
CONFIG: Title: "Idiomas Taalcursus Nederlands-Frans"
ACTION: RegKey: "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion", "SharedDLLs"
ACTION: SystemFile: "C:\WINDOWS\SYSTEM32\VB6STKIT.DLL"
(File currently on disk was already up to date)
ACTION: SystemFile: "C:\WINDOWS\SYSTEM32\COMCAT.DLL"
ACTION: SystemFile: "C:\WINDOWS\SYSTEM32\MSWINSCK.OCX"
ACTION: SystemFile: "C:\WINDOWS\SYSTEM32\MSMAPI32.OCX"
ACTION: SystemFile: "C:\WINDOWS\SYSTEM32\STDOLE2.TLB"
ACTION: SystemFile: "C:\WINDOWS\SYSTEM32\ASYCFILT.DLL"
ACTION: SystemFile: "C:\WINDOWS\SYSTEM32\OLEPRO32.DLL"
ACTION: SystemFile: "C:\WINDOWS\SYSTEM32\OLEAUT32.DLL"
ACTION: SystemFile: "C:\WINDOWS\SYSTEM32\msvbvm60.dll"
ACTION: DllSelfRegister: "C:\WINDOWS\SYSTEM32\COMCAT.DLL"
ACTION: DllSelfRegister: "C:\WINDOWS\SYSTEM32\MSWINSCK.OCX"
ACTION: DllSelfRegister: "C:\WINDOWS\SYSTEM32\MSMAPI32.OCX"
ACTION: TLBRegister: "C:\WINDOWS\SYSTEM32\STDOLE2.TLB"
ACTION: DllSelfRegister: "C:\WINDOWS\SYSTEM32\OLEPRO32.DLL"
ACTION: DllSelfRegister: "C:\WINDOWS\SYSTEM32\OLEAUT32.DLL"
ACTION: DllSelfRegister: "C:\WINDOWS\SYSTEM32\msvbvm60.dll"
NOTE: End of the bootstrapper section
NOTE: Now spawning the main Setup program 'Setup1.exe'....
ACTION: RegKey: "HKEY_LOCAL_MACHINE\SOFTWARE", "Idiomas\TaalCursus\FR_NL"
*** ERROR: Setup1::buildcode_0004h => 6: Overflow
*** ERROR: Oeps... De fout die nu is opgetreden kan niet verklaard worden!
*** ERROR: Kijk eens in ST6UNST.??? of IDIOMAS_SETUP.INI in de 'Windows' folder, misschien bevatten die files een verklaring.
*** ERROR: (User Responded with 'Opnieuw')
*** ERROR: (User Responded with 'Annuleren')
*** WARNING: Ik was nog niet klaar!
*** WARNING: Zeg eens... als u nu stopt dan is dit programma niet volledig geïnstalleerd.
*** WARNING: Wilt u de setup verlaten?
*** WARNING: (User Responded with 'Ja')
*** WARNING: Ja lap! Idiomas Taalcursus Nederlands-Frans Setup was onderbroken vóór de installatie van het programma volledig gedaan was.
*** WARNING: U moet Idiomas Taalcursus Nederlands-Frans Setup opnieuw volledig uitvoeren vooraleer het programma kan gebruikt worden.
*** WARNING: (User Responded with 'Oké')
Quelqu'un pourrait-il me dire ce que je pourrais faire pour corriger tout ça?
"Mieux vaut prévenir que guérir..."
  1. Oui mais comment on fait nous pour comprendre les messages d'erreur ? :(
    1. sais pas!!!! Dictionnaire?? (rire)....
    2. @taharqaBen bonne chance on est pas des pigeons non plus =D !
    3. @EminoMenekofranchement, tu ne comptrends pas l'humour!!! merci quand même, mais mon but n'était pas de profiter de personne....suis désolée de t'avoir choqué.....
  2. C'est pas beaucoup en français les messages d'erreur ni même en anglais....
    C'est balo...
    1. désolée,EminoMeneko.... Mais bon, mon mari est neerlandophone, et veut apprendre le français!!!!
      je sais, pas facile!!!!
