Probleme t_else
Bonjour, voila maintenant le probleme t_string resolu jai se message d'erreur ci:
Parse error: syntax error, unexpected T_ELSE in /home/.nfs2/ron67/www/nk/index.php on line 85
et voici mon fichier index.php
<?php
// Nuked-KlaN - PHP Portal                                                  //
// https://nuked-klan.org/                                                //
// This program is free software. you can redistribute it and/or modify     //
// it under the terms of the GNU General Public License as published by     //
// the Free Software Foundation; either version 2 of the License.           //
define ("INDEX_CHECK", 1);
include ("conf.inc.php");
if (!defined("NK_OPEN"))
    echo "<br /><br /><br /><div style=\"text-align: center;\"><big>Sorry, this website is momently closed, Please try again later.</big></div>";
    exit();
if (!defined("NK_INSTALLED"))
    if (is_file("install.php"))
        header("location: install.php");
else
    if (is_file("install.php") || is_file("update.php"))
        echo "<br /><br /><br /><div style=\"text-align: center;\"><big>Warning ! <b>install.php</b> and <b>update.php</b> must be removed before continuing !</big></div>";
        exit();
include ("nuked.php");
$session = session_check();
if ($session == 1) $user = secure();
else $user = "";
$session_admin = admin_check();
$check_ip = banip();
if ($check_ip != "")
    $url_ban = "ban.php?ip_ban=" . $check_ip;
    redirect($url_ban, 0);
    exit();
if (isset($nuked_nude) && $nuked_nude != "") $im_file = $nuked_nude;
else if (isset($page) && $page != "") $im_file = $page;
else $im_file = "index";
// Securite par phpSecure.info
if (ereg("\.\.", $theme) || ereg("\.\.", $language) || ereg("\.\.", $file) || ereg("\.\.", $im_file) || eregi("http\:\/\/", $file) || eregi("http\:\/\/", $im_file))
    die("<br /><br /><br /><div style=\"text-align: center;\"><big>What are you trying to do ?</big></div>");
$file = trim($file);
$im_file = trim($im_file);
$theme = trim($theme);
$language = trim($language);
// Fin
if ($nuked['nk_status'] == "closed" && $user[1] < 9 && $op != "login_screen" && $op != "login_message" && $op != "login");
    include ("themes/" . $theme . "/colors.php");
    translate("lang/" . $language . ".lang.php");
    echo "<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Strict//EN\" \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd\">\n"
    . "<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"fr\">\n"
    . "<head><title>" . $nuked['name'] . " :: " . $nuked['slogan'] . " ::</title>\n"
    . "<meta http-equiv=\"Content-Type\" content=\"text/html; charset=iso-8859-1\" />\n"
    . "<meta http-equiv=\"content-style-type\" content=\"text/css\" />\n"
    . "<link title=\"style\" type=\"text/css\" rel=\"stylesheet\" href=\"themes/" . $theme . "/style.css\" /></head>\n"
    . "<body style=\"background: " . $bgcolor2 . ";\"><div><br /><br /><br /><br /><br /><br /><br /><br /></div>\n"
    . "<table style=\"margin-left: auto;margin-right: auto;text-align: left;background: " . $bgcolor3 . ";\" cellspacing=\"1\" cellpadding=\"20\">\n"
    . "<tr><td style=\"background: " . $bgcolor1 . ";\" align=\"center\"><big><b>" . $nuked['name'] . " - " . $nuked['slogan'] . "</b></big><br /><br />\n"
    . _SITECLOSED . "</td></tr></table></body></html>";
else if (($file == "Admin" || $page == "admin" || $nuked_nude == "admin") && $session_admin == 0)
    include ("themes/" . $theme . "/theme.php");
    if (!isset($nuked_nude)) top();
    include("modules/Admin/login.php");
	footer();
    	include("Includes/copyleft.php");
else
    if ($file != "Admin" && $page != "admin" && $nuked_nude != "admin" && $op != "smilies" && $session_admin == 1) setcookie($cookie_admin, "", time() - 86400);
    visits();
	if (defined("NK_GZIP") && @extension_loaded('zlib') && !@ini_get('zlib.output_compression') && @phpversion() >= "4.0.4")
	    ob_start("ob_gzhandler");
	top();
	echo "<script type=\"text/javascript\" src=\"infobulle.js\"></script>"
	. "<script type=\"text/javascript\">InitBulle('" . $bgcolor2 . "', '" . $bgcolor3 . "', 2);</script>";
	if ($nuked['nk_status'] == "closed" && $user[1] == 9)
	    echo "<table style=\"background: " . $bgcolor3 . ";\" width=\"100%\" cellspacing=\"1\" cellpadding=\"8\">\n"
	    ."<tr><td style=\"background: " . $bgcolor2 . ";\" ><big><b>" . _YOURSITEISCLOSED . " :<br /><br/ >" . $nuked['url'] . "/index.php?file=User&amp;op=login_screen</b></big></td></tr></table><br />\n";
    if (is_file("modules/" . $file . "/" . $im_file . ".php"))
	include("modules/" . $file . "/" . $im_file . ".php");
    else
	include("modules/404/index.php");
	if ($user[5] > 0 && !isset($_COOKIE['popup']) && $file != "User" && $file != "Userbox")
	    echo "<div id=\"popup_dhtml\" style=\"position:absolute;top:0;left:0;visibility:visible;z-index:10\"></div>\n"
	    . "<script type=\"text/javascript\" src=\"popup.js\"></script>\n"
	    . "<script type=\"text/javascript\">popup('" . $bgcolor2 . "', '" . $bgcolor3 . "', '" . _NEWMESSAGESTART . "&nbsp;" . $user[5] . "&nbsp;" . _NEWMESSAGEEND . "', '" . _CLOSEWINDOW . "', 'index.php?file=Userbox', 350, 100);</script>\n";
	footer();
  1. sil vous plait aidé moi je suis perdu et ji es passer toute lapremidi sur cette enigme de :
    Parse error: syntax error, unexpected T_STRING, expecting ',' or ';' in /home/.nfs2/ron67/www/nk/index.php on line 76
    1. ouki merci j'ai retirer le ; de la ligne 69 et sa me remet le message d'erreur de tout a l'heure:
      et le php et bcp moin long je ne voit pas pourquoi l'erreur se re répete. (dsl pour le message d'avant je pencais
      lavoir supprimer)
      <?php
          exit();
      else
              exit();
      else $user = "";
          exit();
      // Fin
      	footer();
      else
          visits();
      	top();
          else
      	footer();
        ben voyons... tu consommes, tu te donnes pas la peine de remercier, t'es pas capable de fair eune recherche google pour chercher a savoir d'ou vient l'erreur ? t'es pas en mesure de compter jusqu'a 86 pour repérer d'ou vient l'erreur ?
        tu vas nous balancer toutes les pages les unes après les autres, ou bien... ?
        enleves le ; a la ligne 69
