Connection internet wifi/ethernet impossible
Bonjour tout le monde ,
Alors voila j'ai une machine avec ubuntu 14.04 lts , jusque la tout vas bien, sauf que je n'arrive plus a me connecter ni en wifi ni en ethernet.
Pouvez vous m'aider a resoudre ce probleme ?
Bonne journée .
Bonne journée .
belhani@Belhani-Linux:~$ sudo su
[sudo] password for belhani:
root@Belhani-Linux:/home/belhani# lspci
00:00.0 Host bridge: Intel Corporation 4th Gen Core Processor DRAM Controller (rev 06)
00:01.0 PCI bridge: Intel Corporation Xeon E3-1200 v3/4th Gen Core Processor PCI Express x16 Controller (rev 06)
00:14.0 USB controller: Intel Corporation 8 Series/C220 Series Chipset Family USB xHCI (rev 05)
00:16.0 Communication controller: Intel Corporation 8 Series/C220 Series Chipset Family MEI Controller #1 (rev 04)
00:19.0 Ethernet controller: Intel Corporation Ethernet Connection I217-V (rev 05)
00:1a.0 USB controller: Intel Corporation 8 Series/C220 Series Chipset Family USB EHCI #2 (rev 05)
00:1b.0 Audio device: Intel Corporation 8 Series/C220 Series Chipset High Definition Audio Controller (rev 05)
00:1c.0 PCI bridge: Intel Corporation 8 Series/C220 Series Chipset Family PCI Express Root Port #1 (rev d5)
00:1c.1 PCI bridge: Intel Corporation 8 Series/C220 Series Chipset Family PCI Express Root Port #2 (rev d5)
00:1c.3 PCI bridge: Intel Corporation 8 Series/C220 Series Chipset Family PCI Express Root Port #4 (rev d5)
00:1c.4 PCI bridge: Intel Corporation 8 Series/C220 Series Chipset Family PCI Express Root Port #5 (rev d5)
00:1d.0 USB controller: Intel Corporation 8 Series/C220 Series Chipset Family USB EHCI #1 (rev 05)
00:1f.0 ISA bridge: Intel Corporation Z87 Express LPC Controller (rev 05)
00:1f.2 SATA controller: Intel Corporation 8 Series/C220 Series Chipset Family 6-port SATA Controller 1 [AHCI mode] (rev 05)
00:1f.3 SMBus: Intel Corporation 8 Series/C220 Series Chipset Family SMBus Controller (rev 05)
01:00.0 VGA compatible controller: NVIDIA Corporation GK106 [GeForce GTX 660] (rev a1)
01:00.1 Audio device: NVIDIA Corporation GK106 HDMI Audio Controller (rev a1)
03:00.0 SATA controller: ASMedia Technology Inc. ASM1062 Serial ATA Controller (rev 01)
04:00.0 PCI bridge: PLX Technology, Inc. PEX 8605 PCI Express 4-port Gen2 Switch (rev aa)
05:01.0 PCI bridge: PLX Technology, Inc. PEX 8605 PCI Express 4-port Gen2 Switch (rev aa)
05:02.0 PCI bridge: PLX Technology, Inc. PEX 8605 PCI Express 4-port Gen2 Switch (rev aa)
05:03.0 PCI bridge: PLX Technology, Inc. PEX 8605 PCI Express 4-port Gen2 Switch (rev aa)
08:00.0 Network controller: Qualcomm Atheros AR9462 Wireless Network Adapter (rev 01)
root@Belhani-Linux:/home/belhani# lsusb
Bus 002 Device 002: ID 8087:8000 Intel Corp.
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 002: ID 8087:8008 Intel Corp.
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 002: ID 174c:3074 ASMedia Technology Inc.
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 005: ID 0b05:17d0 ASUSTek Computer, Inc.
Bus 003 Device 002: ID 174c:2074 ASMedia Technology Inc.
Bus 003 Device 004: ID 046d:c52b Logitech, Inc. Unifying Receiver
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
root@Belhani-Linux:/home/belhani# ifconfig -a
eth0 Link encap:Ethernet HWaddr d8:50:e6:3d:39:32
inet adr:127.0.0.1 Bcast:127.255.255.255 Masque:255.0.0.0
adr inet6: fe80::da50:e6ff:fe3d:3932/64 Scope:Lien
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
Packets reçus:737 erreurs:0 :7 overruns:0 frame:0
TX packets:44 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 lg file transmission:1000
Octets reçus:105789 (105.7 KB) Octets transmis:6642 (6.6 KB)
Interruption:20 Mémoire:ec400000-ec420000
lo Link encap:Boucle locale
inet adr:127.0.0.1 Masque:255.0.0.0
adr inet6: ::1/128 Scope:Hôte
UP LOOPBACK RUNNING MTU:65536 Metric:1
Packets reçus:284 erreurs:0 :0 overruns:0 frame:0
TX packets:284 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 lg file transmission:0
Octets reçus:26326 (26.3 KB) Octets transmis:26326 (26.3 KB)
wlan0 Link encap:Ethernet HWaddr 24:0a:64:8b:07:e7
inet adr:192.168.1.53 Bcast:192.168.1.255 Masque:255.255.255.0
BROADCAST MULTICAST MTU:1500 Metric:1
Packets reçus:0 erreurs:0 :0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
Octets reçus:0 (0.0 B) Octets transmis:0 (0.0 B)
Packets reçus:761 erreurs:0 :7 overruns:0 frame:0
Octets reçus:109125 (109.1 KB) Octets transmis:6642 (6.6 KB)
root@Belhani-Linux:/home/belhani# iwconfig
eth0 no wireless extensions.
lo no wireless extensions.
wlan0 IEEE 802.11abgn ESSID:off/any
Mode:Managed Access Point: Not-Associated Tx-Power=off
Retry long limit:7 RTS thr:off Fragment thr:off
Encryption key:off
Power Management:off
bonsoir,
alors j'ai mis les dns SFR trouver ici :
https://lafibre.info/sfr-les-news/dns-primaire-sfr/?PHPSESSID=06pqgr63l31ljcjfv721o7hch5
ca marche toujours pas :( , peut etre le localhost ? localnet ? allnodes ? ....
belhani@Belhani-Linux:~$ cat /etc/resolv.conf
# Dynamic resolv.conf(5) file for glibc resolver(3) generated by resolvconf(8) # DO NOT EDIT THIS FILE BY HAND -- YOUR CHANGES WILL BE OVERWRITTEN
nameserver 178.32.122.65
nameserver 37.59.72.228
belhani@Belhani-Linux:~$ cat /etc/hosts
127.0.0.1 localhost
127.0.1.1 Belhani-Linux
# The following lines are desirable for IPv6 capable hosts
::1 ip6-localhost ip6-loopback
fe00::0 ip6-localnet
ff00::0 ip6-mcastprefix
ff02::1 ip6-allnodes
ff02::2 ip6-allrouters
Posté depuis CCM Live forum pour Android-
ContributeurEssaie d'ouvrir Network Manager (l'interface de configuration du réseau, c'est elle qui est responsable de l'écriture du fichier /ets/resolv.conf) et d'y supprimer les serveurs DNS en les remplaçant par celui (ou ceux) de ton FAI.
Ceux en place actuellement sont ceux d'OVH (178.32.122.65 et 37.59.72.228).
ContributeurSalut,
C'est bizarre, parce qu'apparemment tu avais bien une connexion wifi :wlan0 Link encap:Ethernet HWaddr 24:0a:64:8b:07:e7
Quel est ton FAI ? Quelle box ?
Le câble Ethernet (RJ45) est bien branché ?
Contributeur
Contributeur@ridouchetNon.
Par contre si j'en crois plusieurs post sur le net (notamment celui-ci), les drivers pour tes connexions (filaire et wifi) devraient être bons ;-\
Je ne sais plus si inxi est installé par défaut sur Ubuntu (au cas ou installe-le), mais que te renvoie la commande :inxi -Nx
