Probleme OpenIMS
Bonjour , je suis entrain de installer OpenIMS core et c'est la premiere fois que je travaille avec sur mon ubuntu 12.04 alors je suis entrain de suivre ce tuto http://18382.whserv.de/admin/index.php en fait quant j'ai essayer dde faire ./pcscf.sh ./icscf.sh ./scscf.sh j'obtient toujours cet erreur est ce quelcun peut m'aider et merci
l'erreur :
0(12895) ERROR: load_module: could not open module </opt/OpenIMSCore/ser_ims/modules/sl/sl.so>: /opt/OpenIMSCore/ser_ims/modules/sl/sl.so: cannot open shared object file: No such file or directory
0(12895) parse error (28,13-14): failed to load module
0(12895) ERROR: load_module: could not open module </opt/OpenIMSCore/ser_ims/modules/tm/tm.so>: /opt/OpenIMSCore/ser_ims/modules/tm/tm.so: cannot open shared object file: No such file or directory
0(12895) parse error (30,13-14): failed to load module
0(12895) ERROR: load_module: could not open module </opt/OpenIMSCore/ser_ims/modules/rr/rr.so>: /opt/OpenIMSCore/ser_ims/modules/rr/rr.so: cannot open shared object file: No such file or directory
0(12895) parse error (35,13-14): failed to load module
0(12895) ERROR: load_module: could not open module </opt/OpenIMSCore/ser_ims/modules/maxfwd/maxfwd.so>: /opt/OpenIMSCore/ser_ims/modules/maxfwd/maxfwd.so: cannot open shared object file: No such file or directory
0(12895) parse error (36,13-14): failed to load module
0(12895) ERROR: load_module: could not open module </opt/OpenIMSCore/ser_ims/modules/textops/textops.so>: /opt/OpenIMSCore/ser_ims/modules/textops/textops.so: cannot open shared object file: No such file or directory
0(12895) parse error (37,13-14): failed to load module
0(12895) ERROR: load_module: could not open module </opt/OpenIMSCore/ser_ims/modules/enum/enum.so>: /opt/OpenIMSCore/ser_ims/modules/enum/enum.so: cannot open shared object file: No such file or directory
0(12895) parse error (38,13-14): failed to load module
0(12895) ERROR: load_module: could not open module </opt/OpenIMSCore/ser_ims/modules/scscf/scscf.so>: /opt/OpenIMSCore/ser_ims/modules/scscf/scscf.so: cannot open shared object file: No such file or directory
0(12895) parse error (40,13-14): failed to load module
0(12895) set_mod_param_regex: No module matching <scscf> found
0(12895) parse error (42,18-19): Can't set module parameter
0(12895) parse error (47,18-19): Can't set module parameter
0(12895) parse error (48,18-19): Can't set module parameter
0(12895) parse error (49,18-19): Can't set module parameter
0(12895) parse error (50,17-18): Can't set module parameter
0(12895) parse error (51,17-18): Can't set module parameter
0(12895) parse error (53,17-18): Can't set module parameter
0(12895) parse error (58,18-19): Can't set module parameter
0(12895) parse error (60,19-20): Can't set module parameter
0(12895) parse error (62,20-21): Can't set module parameter
0(12895) parse error (63,18-19): Can't set module parameter
0(12895) parse error (64,23-24): Can't set module parameter
0(12895) parse error (65,18-19): Can't set module parameter
0(12895) parse error (67,18-19): Can't set module parameter
0(12895) parse error (80,17-18): Can't set module parameter
0(12895) parse error (81,17-18): Can't set module parameter
0(12895) parse error (83,20-21): Can't set module parameter
0(12895) parse error (84,18-19): Can't set module parameter
0(12895) parse error (85,23-24): Can't set module parameter
0(12895) parse error (87,19-20): Can't set module parameter
0(12895) parse error (88,20-21): Can't set module parameter
0(12895) parse error (89,17-18): Can't set module parameter
0(12895) parse error (90,21-22): Can't set module parameter
0(12895) parse error (91,18-19): Can't set module parameter
0(12895) parse error (94,17-18): Can't set module parameter
0(12895) parse error (97,17-18): Can't set module parameter
0(12895) ERROR: load_module: could not open module </opt/OpenIMSCore/ser_ims/modules/isc/isc.so>: /opt/OpenIMSCore/ser_ims/modules/isc/isc.so: cannot open shared object file: No such file or directory
0(12895) parse error (106,13-14): failed to load module
0(12895) set_mod_param_regex: No module matching <isc> found
0(12895) parse error (108,18-19): Can't set module parameter
0(12895) parse error (109,20-21): Can't set module parameter
0(12895) parse error (110,21-22): Can't set module parameter
0(12895) parse error (111,19-20): Can't set module parameter
0(12895) set_mod_param_regex: No module matching <rr> found
0(12895) parse error (118,19-20): Can't set module parameter
0(12895) parse error (146,42-43): unknown command, missing loadmodule?
0(12895) parse error (156,33-34): unknown command, missing loadmodule?
0(12895) parse error (162,15-16): unknown command, missing loadmodule?
0(12895) parse error (163,11-12): unknown command, missing loadmodule?
0(12895) parse error (167,27-28): unknown command, missing loadmodule?
0(12895) parse error (167,44-45): unknown command, missing loadmodule?
0(12895) parse error (169,29-30): unknown command, missing loadmodule?
0(12895) parse error (170,32-33): unknown command, missing loadmodule?
0(12895) parse error (177,24-25): unknown command, missing loadmodule?
0(12895) parse error (181,24-25): unknown command, missing loadmodule?
0(12895) parse error (188,30-31): unknown command, missing loadmodule?
0(12895) parse error (189,33-34): unknown command, missing loadmodule?
0(12895) parse error (191,23-24): unknown command, missing loadmodule?
0(12895) parse error (206,34-35): unknown command, missing loadmodule?
0(12895) parse error (207,22-23): unknown command, missing loadmodule?
0(12895) parse error (212,23-24): unknown command, missing loadmodule?
0(12895) parse error (224,31-32): unknown command, missing loadmodule?
0(12895) parse error (225,25-26): unknown command, missing loadmodule?
0(12895) parse error (233,13-14): unknown command, missing loadmodule?
0(12895) parse error (239,35-36): unknown command, missing loadmodule?
0(12895) parse error (242,27-28): unknown command, missing loadmodule?
0(12895) parse error (243,19-20): unknown command, missing loadmodule?
0(12895) parse error (245,19-20): unknown command, missing loadmodule?
0(12895) parse error (248,29-30): unknown command, missing loadmodule?
0(12895) parse error (249,28-29): unknown command, missing loadmodule?
0(12895) parse error (252,20-21): unknown command, missing loadmodule?
0(12895) parse error (253,30-31): unknown command, missing loadmodule?
0(12895) parse error (256,20-21): unknown command, missing loadmodule?
0(12895) parse error (260,29-30): unknown command, missing loadmodule?
0(12895) parse error (261,28-29): unknown command, missing loadmodule?
0(12895) parse error (265,21-22): unknown command, missing loadmodule?
0(12895) parse error (269,22-23): unknown command, missing loadmodule?
0(12895) parse error (273,20-21): unknown command, missing loadmodule?
0(12895) parse error (297,28-29): unknown command, missing loadmodule?
0(12895) parse error (298,27-28): unknown command, missing loadmodule?
0(12895) parse error (301,19-20): unknown command, missing loadmodule?
0(12895) parse error (302,29-30): unknown command, missing loadmodule?
0(12895) parse error (305,19-20): unknown command, missing loadmodule?
0(12895) parse error (309,28-29): unknown command, missing loadmodule?
0(12895) parse error (310,27-28): unknown command, missing loadmodule?
0(12895) parse error (314,20-21): unknown command, missing loadmodule?
0(12895) parse error (318,21-22): unknown command, missing loadmodule?
0(12895) parse error (322,19-20): unknown command, missing loadmodule?
0(12895) parse error (328,23-24): unknown command, missing loadmodule?
0(12895) parse error (337,23-24): unknown command, missing loadmodule?
0(12895) parse error (338,17-18): unknown command, missing loadmodule?
0(12895) parse error (340,29-30): unknown command, missing loadmodule?
0(12895) parse error (341,17-18): unknown command, missing loadmodule?
0(12895) parse error (347,35-36): unknown command, missing loadmodule?
0(12895) parse error (348,39-40): unknown command, missing loadmodule?
0(12895) parse error (354,18-19): unknown command, missing loadmodule?
0(12895) parse error (355,18-19): unknown command, missing loadmodule?
0(12895) parse error (358,25-26): unknown command, missing loadmodule?
0(12895) parse error (359,16-17): unknown command, missing loadmodule?
0(12895) parse error (362,22-23): unknown command, missing loadmodule?
0(12895) parse error (363,19-20): unknown command, missing loadmodule?
0(12895) parse error (369,17-18): unknown command, missing loadmodule?
0(12895) parse error (373,16-17): unknown command, missing loadmodule?
0(12895) parse error (394,27-28): unknown command, missing loadmodule?
0(12895) parse error (395,22-23): unknown command, missing loadmodule?
0(12895) parse error (401,29-30): unknown command, missing loadmodule?
0(12895) parse error (402,21-22): unknown command, missing loadmodule?
0(12895) parse error (404,24-25): unknown command, missing loadmodule?
0(12895) parse error (405,23-24): unknown command, missing loadmodule?
0(12895) parse error (410,14-15): unknown command, missing loadmodule?
0(12895) parse error (412,17-18): unknown command, missing loadmodule?
0(12895) parse error (415,25-26): unknown command, missing loadmodule?
0(12895) parse error (416,16-17): unknown command, missing loadmodule?
0(12895) parse error (417,18-19): unknown command, missing loadmodule?
0(12895) parse error (424,21-22): unknown command, missing loadmodule?
0(12895) parse error (425,29-30): unknown command, missing loadmodule?
0(12895) parse error (432,15-16): unknown command, missing loadmodule?
0(12895) parse error (437,27-28): unknown command, missing loadmodule?
0(12895) parse error (438,25-26): unknown command, missing loadmodule?
0(12895) parse error (442,15-16): unknown command, missing loadmodule?
0(12895) parse error (443,22-23): unknown command, missing loadmodule?
0(12895) parse error (451,25-26): unknown command, missing loadmodule?
0(12895) parse error (472,25-26): unknown command, missing loadmodule?
0(12895) parse error (490,23-24): unknown command, missing loadmodule?
0(12895) parse error (491,16-17): unknown command, missing loadmodule?
0(12895) parse error (492,18-19): unknown command, missing loadmodule?
0(12895) parse error (493,26-27): unknown command, missing loadmodule?
0(12895) parse error (500,22-23): unknown command, missing loadmodule?
0(12895) parse error (501,30-31): unknown command, missing loadmodule?
0(12895) parse error (508,16-17): unknown command, missing loadmodule?
0(12895) parse error (509,18-19): unknown command, missing loadmodule?
0(12895) parse error (513,28-29): unknown command, missing loadmodule?
0(12895) parse error (515,26-27): unknown command, missing loadmodule?
0(12895) parse error (519,16-17): unknown command, missing loadmodule?
0(12895) parse error (521,17-18): unknown command, missing loadmodule?
0(12895) parse error (522,18-19): unknown command, missing loadmodule?
0(12895) parse error (535,14-15): unknown command, missing loadmodule?
0(12895) parse error (538,21-22): unknown command, missing loadmodule?
0(12895) parse error (549,18-19): unknown command, missing loadmodule?
0(12895) parse error (550,16-17): unknown command, missing loadmodule?
0(12895) parse error (553,15-16): unknown command, missing loadmodule?
0(12895) parse error (554,22-23): unknown command, missing loadmodule?
0(12895) parse error (566,20-21): unknown command, missing loadmodule?
0(12895) parse error (586,27-28): unknown command, missing loadmodule?
0(12895) parse error (587,22-23): unknown command, missing loadmodule?
0(12895) parse error (593,29-30): unknown command, missing loadmodule?
0(12895) parse error (594,21-22): unknown command, missing loadmodule?
0(12895) parse error (596,24-25): unknown command, missing loadmodule?
0(12895) parse error (597,23-24): unknown command, missing loadmodule?
0(12895) parse error (602,14-15): unknown command, missing loadmodule?
0(12895) parse error (605,25-26): unknown command, missing loadmodule?
0(12895) parse error (606,16-17): unknown command, missing loadmodule?
0(12895) parse error (607,18-19): unknown command, missing loadmodule?
0(12895) parse error (612,16-17): unknown command, missing loadmodule?
0(12895) parse error (614,20-21): unknown command, missing loadmodule?
0(12895) parse error (615,20-21): unknown command, missing loadmodule?
0(12895) parse error (618,17-18): unknown command, missing loadmodule?
0(12895) parse error (629,15-16): unknown command, missing loadmodule?
0(12895) parse error (632,18-19): unknown command, missing loadmodule?
0(12895) parse error (634,15-16): unknown command, missing loadmodule?
0(12895) parse error (635,22-23): unknown command, missing loadmodule?
0(12895) parse error (644,25-26): unknown command, missing loadmodule?
0(12895) parse error (657,28-29): unknown command, missing loadmodule?
0(12895) parse error (675,23-24): unknown command, missing loadmodule?
0(12895) parse error (676,16-17): unknown command, missing loadmodule?
0(12895) parse error (677,18-19): unknown command, missing loadmodule?
0(12895) parse error (678,26-27): unknown command, missing loadmodule?
0(12895) parse error (683,17-18): unknown command, missing loadmodule?
0(12895) parse error (689,18-19): unknown command, missing loadmodule?
0(12895) parse error (694,16-17): unknown command, missing loadmodule?
0(12895) parse error (695,18-19): unknown command, missing loadmodule?
0(12895) parse error (697,16-17): unknown command, missing loadmodule?
0(12895) parse error (699,17-18): unknown command, missing loadmodule?
0(12895) parse error (700,18-19): unknown command, missing loadmodule?
0(12895) parse error (710,14-15): unknown command, missing loadmodule?
0(12895) parse error (713,21-22): unknown command, missing loadmodule?
0(12895) parse error (716,18-19): unknown command, missing loadmodule?
0(12895) parse error (727,16-17): unknown command, missing loadmodule?
0(12895) parse error (730,15-16): unknown command, missing loadmodule?
0(12895) parse error (731,22-23): unknown command, missing loadmodule?
0(12895) parse error (743,20-21): unknown command, missing loadmodule?
0(12895) parse error (761,18-19): unknown command, missing loadmodule?
0(12895) parse error (787,15-16): unknown command, missing loadmodule?
0(12895) parse error (788,23-24): unknown command, missing loadmodule?
0(12895) parse error (795,25-26): unknown command, missing loadmodule?
ERROR: bad config file (179 errors)
0(12895) INFO:cdp:cdp_exit(): CDiameterPeer stoping ...
./scscf.sh: line 6: 12895 Segmentation fault (core dumped) LD_LIBRARY_PATH=/usr/local/lib/ser /opt/OpenIMSCore/ser_ims/ser -f /opt/OpenIMSCore/scscf.cfg -D -D
------ Semaphore Arrays --------
key semid owner perms nsems
  1. je ne penses pas vu que je n'ai rien touché au fichiers de configuration mes petit soucis étaient avec la configuration du DNS mais je sais comment le configuré par contre j'ai trouve que /opt/OpenIMSCore/ser_ims/modules/sl/sl.so n'existe pas!! je ne sais pas pourquoi ?
    je peux faire aussi un ping , nslookup , dig et j'obtient des resultats correctes
    1. non pas dans une seule ligne en fait j'ai essayé chacune a part et toujours j'ai le même erreur , pour les étapes précédentes il y a eu quelques soucis mais j'ai arriver a les corrigés
        Je doute, et je parierai même que c'est ce qui provoque toutes ces erreurs ;-(
        Peut-être devrais-tu reconsidérer l'installation en repartant sur des bases saines, non ?
    2. Contributeur
      Euh... tu as tapé la commande telle qu'elle apparaît là, autrement dit sur une seule ligne ?
      La doc que tu pointes en lien préconise de taper chacune d'entre elle dans un terminal à part (du moins un onglet pour chaque commande) ;-\
      Sinon, les autres étapes avant d'en arriver là, se sont-elles déroulées sans aucune erreur ?
