Problème de code
Bonjour, j'ai un problème, les informations ne vont pas dans la base de données pourquoi ?
voici mon code
<?php
if(isset($_POST['Code_barre']) && isset($_POST['Designation']) && isset($_POST['Rayon']) && isset($_POST['Famille']) && isset($_POST['Poids']) && isset($_POST['Date_de_sortie']) && isset($_POST['Prix_de_reprise'])&& isset($_POST['Vente_TTC'])&& isset($_POST['Vente_HT'])&& isset($_POST['Stock'])&& isset($_POST['Neuf'])&& isset($_POST['Occasions']) && $_POST['Code_barre'] != "" && $_POST['Designation'] != "" && $_POST['Rayon'] != "" && $_POST['Famille'] != "" && $_POST['Poids'] != "" && $_POST['Point_de_fidelite'] != "" && $_POST['Date_de_sortie'] != ""&& $_POST['Prix_de_reprise'] != ""&& $_POST['Vente_TTC'] != ""&& $_POST['Vente_HT'] != ""&& $_POST['Stock'] != ""&& $_POST['Neuf'] != ""&& $_POST['Occasions'] != ""){;
    $Code_barre = $_POST['Code_barre'];
	$Designation = $_POST['Designation'];
	$Rayon =$_POST['Rayon'];
	$Famille = $_POST['Famille'];
	$Poids= $_POST['Poids'];
    $Point_de_fidelite = $_POST['Point_de_fidelite'];
	$Date_de_sortie = $_POST['Date_de_sortie'];
    $Prix_de_reprise = $_POST['Prix_de_reprise'];
	$Vente_TTC = $_POST['Vente_TTC'];
	$Vente_HT = $_POST['Vente_HT'];
	$Stock = $_POST['Stock'];
	$Neuf = $_POST['Neuf'];
	$Occasions = $_POST['Ocassions'];
 $connect= mysql_connect('localhost','articles','f2ydYDyjrVBSjx4a') or die('Impossible de se connecter au serveur MySQL');
    mysql_select_db("articles");
    mysql_query("INSERT INTO clients VALUES(Code_barre,Designation,Rayon,Famille,Poids,Point_de_fidelite,Date_de_sortie,Prix_de_reprises,Vente_TTC,Vente_HT,Stock,Neuf,Occasions)VALUES('$Code_barre','$Designation','$Rayon','$Famille','$Poids','$Date_de_sortie','$Prix_de_reprises','$Vente_TTC','$Vente_HT','$Stock','$Neuf','$Occasions')");
<!DOCTYPE html>
<html>
    <head>
	<LINK rel="stylesheet" type="text/css" href="style.css">
        <meta charset="utf-8" />
        <title>Nouvel articles-CashProg</title>
    </head>
    <body>
<form method="POST" action="nouveauxarticle.php">
<p><font color="red">/!\ Tous les champs doivent être remplis /!\</font></p>
<p>Code barre</p>
<input type="text" name="Code_barre"/>
<p>Designation</p>
<input type="text" name="Designation"/>
<p>Rayon</p>
<input type="text" name="Rayon"/>
<p>Famille</p>
<input type="text" name="Famille"/>
<p>Poids</p>
<input type="text" name="Poids"/>
<p>Point de fidelite</p>
<input type="text" name="Point_de_fidelite"/>
<p>Date de sortie</p>
<input type="text" name="Date_de_sortie"/>
<p>Prix de reprise</p>
<input type="text" name="Prix_de_reprise"/>
<form><SELECT name="Tva" size="1">
<OPTION>0
<OPTION>2.1
<OPTION>5.5
<option>7
<option>19.6
</form>
<p>Vente TTC</p>
<input type="text" name="Vente_TTC"/>
<p>Vente HT</p>
<input type="text" name="Vente_HT"/>
<p>Stock</p>
<input type="text" name="Stock"/>
<FORM>
<INPUT type="checkbox" name="Neuf" value="1"> Neuf
<INPUT type="checkbox" name="Occasions" value="2"> Occasions
</FORM>
<input type="submit" name="Validez" value="Valider"/>
</form>
</body>
</html>
Le problème porte sur l’insertion d’informations issues d’un formulaire PHP vers une base MySQL, avec des erreurs de syntaxe et des incohérences entre les noms de champs et les valeurs. Des fautes de syntaxe apparaissent notamment après l’accolade ouvrante du if et des erreurs de correspondance entre les noms de colonnes, les variables et les valeurs insérées. Des typos et incohérences comme Ocassions vs Occasions, Prix_de_reprise vs Prix_de_reprises, et une variable non définie ou mal écrite impactent l’INSERT, sans parler d’une utilisation dépassée de l’extension MySQL. D’autres éléments évoquent aussi des formulaires HTML multiples et des tags mal fermés, ce qui peut empêcher l’envoi des données et la cohérence entre le formulaire et la requête.
  1. C'est a dire flokocha ?
    1. ['Stock'] != ""&& $_POST['Neuf'] != ""&& $_POST['Occasions'] != ""){;
      ici
    2. Donc je doit mettre le ; est enlever mais je doit mettre ['Stock'] != ""&& $_POST['Neuf'] != ""&& $_POST['Occasions'] != ""){; après mon insert ?
    3. Non c'est modifier voici mon code actuel :
      <?php
       $connect= mysql_connect('localhost','articles','Ay2HV28wy88RxzuA') or die('Impossible de se connecter au serveur MySQL');
          mysql_query("INSERT INTO articles VALUES('".$Code_barre."', '".$Designation."', '".$Rayon."', '".$Famille."', '".$Poids."', '".$Date_de_sortie."', '".$Prix_de_reprise."', '".$Vente_TTC."', '".$Vente_HT."', '".$Stock."')");
      	echo $Code_barre;
      	echo $Designation;
      	echo $Rayon;
      	echo $Famille;
      	echo $Poids;
      	echo $Point_de_fidelite;
      	echo $Date_de_sortie;
          echo $Prix_de_reprise;
      	echo $Vente_TTC;
      	echo $Vente_HT;
      	echo $Stock;
      	echo $Neuf;
      	$Occasions = $_POST['Occasions'];
      	echo $Occasions;
      <!DOCTYPE html>
      <html>
          <head>
          </head>
          <body>
      <p>Code barre</p>
      <p>Designation</p>
      <p>Rayon</p>
      <p>Famille</p>
      <p>Poids</p>
      <p>Vente TTC</p>
      <p>Vente HT</p>
      <p>Stock</p>
      </form>
      </body>
      </html>
      <OPTION>0
      <OPTION>2.1
      <OPTION>5.5
      <option>7
      <option>19.6
      </select>
    4. je ne doit pas metttre cela ?
      	echo $Code_barre;
      	echo $Designation;
    5. si si mon message etait juste obsolète ..
      pourquoi tes deux dernier input et select ne sont pas dans ta balise FORM ?
  2. avec les echo rien ne se passe vocii mon code
    	echo $Code_barre;
    	echo $Designation;
    	echo $Rayon;
    	echo $Famille;
    	echo $Poids;
    	echo $Vente_TTC;
    	echo $Vente_HT;
    	echo $Stock;
    	echo $Neuf;
    	echo $Occasions;
    1. Il y a déjà une erreur de syntaxe : tu as un point virugle immédiatement après l'accolade ouvrante de ton if.
      Ensuite il faut aussi vérifier la cohérence entre ton insert et la structure de ta base. Selon le type de données défini en base pour chaque champ, les guillemets doivent ou ne doivent pas entourer ta variable php dans ton insert.
      1. effectivement c'est un probleme ca ^^
    2. $Code_barre = $_POST['Code_barre'];
      echo $Code_barre;
      et tu fais ça pour les autre aussi pour voir si il les recupère bien
      1. bonjour,
        essaie déjà de faire des echo pour voir si il récupere bien toute tes valeurs
