Probleme installation postgre
bonjour!
j'essai actuellement d'installer posgre cependant ken je tape la commance : ./configure il me sort des erreurs
voici ce que cela m'affiche:
[*******@localhost postgresql-8.0.3]$ ./configure
checking build system type... i686-pc-linux-gnu
checking host system type... i686-pc-linux-gnu
checking which template to use... linux
checking whether to build with 64-bit integer date/time support... no
checking whether NLS is wanted... no
checking for default port number... 5432
checking for gcc... gcc
checking for C compiler default output... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking if gcc supports -Wdeclaration-after-statement... yes
checking if gcc supports -Wold-style-definition... yes
checking if gcc supports -Wendif-labels... yes
checking if gcc supports -fno-strict-aliasing... yes
configure: using CFLAGS=-O2 -Wall -Wmissing-prototypes -Wpointer-arith -Wdeclaration-after-statement -Wold-style-definition -Wendif-labels -fno-strict-aliasing
checking whether the C compiler still works... yes
checking how to run the C preprocessor... gcc -E
checking allow thread-safe client libraries... no
checking whether to build with Tcl... no
checking whether to build Perl modules... no
checking whether to build Python modules... no
checking whether to build with Kerberos 4 support... no
checking whether to build with Kerberos 5 support... no
checking whether to build with PAM support... no
checking whether to build with Rendezvous support... no
checking whether to build with OpenSSL support... no
configure: using CPPFLAGS=-D_GNU_SOURCE
configure: using LDFLAGS=
checking for gawk... gawk
checking for flex... no
configure: WARNING:
*** Without Flex you will not be able to build PostgreSQL from CVS or
*** change any of the scanner definition files. You can obtain Flex from
*** a GNU mirror site. (If you are using the official distribution of
*** PostgreSQL then you do not need to worry about this because the Flex
*** output is pre-generated.)
checking whether ln -s works... yes
checking for ld used by GCC... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... yes
checking for ranlib... ranlib
checking for lorder... no
checking for tar... /bin/tar
checking for strip... strip
checking whether it is possible to strip libraries... yes
checking for bison... no
configure: WARNING:
*** Without Bison you will not be able to build PostgreSQL from CVS or
*** change any of the parser definition files. You can obtain Bison from
*** PostgreSQL then you do not need to worry about this because the Bison
*** output is pre-generated.) To use a different yacc program (possible,
*** but not recommended), set the environment variable YACC before running
*** 'configure'.
checking for perl... /usr/bin/perl
checking for main in -lbsd... yes
checking for setproctitle in -lutil... no
checking for main in -lm... yes
checking for main in -ldl... yes
checking for main in -lnsl... yes
checking for main in -lsocket... no
checking for main in -lipc... no
checking for main in -lIPC... no
checking for main in -llc... no
checking for main in -ldld... no
checking for main in -lld... no
checking for main in -lcompat... no
checking for main in -lBSD... no
checking for main in -lgen... no
checking for main in -lPW... no
checking for main in -lresolv... yes
checking for library containing getopt_long... none required
checking for main in -lunix... no
checking for library containing crypt... -lcrypt
checking for library containing fdatasync... none required
checking for shmget in -lcygipc... no
checking for readline... no
configure: error: readline library not found
If you have readline already installed, see config.log for details on the
failure. It is possible the compiler isn't looking in the proper directory.
Use --without-readline to disable readline support.
pouvez vous me dire ce qu'il me manque ? merci
  1. oui c'était tout bete
    merci pour vos reponses
    1. ou bien installer cette librairie à partir de synaptic; en fait elle sert à l'édition facile des lignes et une recherche de l'historique des commandes). Si tu ne veux pas l'utiliser, il te faut spécifier --without-readline au moment d'exécuter la commande configure. Une alternative possible est l'utilisation de la bibliothèqe libedit sous license BSD
  2. la solution est ecrite en plus
    donc
    ./configure --without-readline
