Problème urban terror
J'avais urban terror,je jouais etc ...tout allait bien ^^
Et j'ai voulu mettre la résolution à fond,le jeu a merdé,s'est coupé.
Mainteant quand je lance urban terror,la console me dit erreur,regardez le rapport:
ioQ3 1.35urt win-x86 Dec 20 2007
----- FS_Startup -----
Going through search path...
8669 files in pk3 files
execing default.cfg
execing q3config.cfg
execing autoexec.cfg
Hunk_Clear: reset the hunk ok
...detecting CPU, found Intel Pentium III
----- Client Initialization -----
Couldn't read q3history.
----- Initializing Renderer ----
QKEY found.
----- Client Initialization Complete -----
----- R_Init -----
Initializing OpenGL subsystem
...initializing QGL
...calling LoadLibrary( 'C:\Windows\system32\opengl32.dll' ): succeeded
...setting mode 9: 1600 1200 FS
...using colorsbits of 32
...calling CDS: failed, bad mode
...trying next higher resolution: failed, bad mode
...restoring display settings
...registered window class
...created window@3,22 (1606x1228)
Initializing OpenGL driver
...getting DC: succeeded
...GLW_ChoosePFD( 32, 24, 8 )
...125 PFDs found
...hardware acceleration found
...PIXELFORMAT 9 selected
...creating GL context: succeeded
...making context current: succeeded
...WARNING: fullscreen unavailable in this mode
...using colorsbits of 16
...window already present, CreateWindowEx skipped
...shutting down QGL
...unloading OpenGL DLL
...assuming '3dfxvgl' is a standalone driver
...initializing QGL
...WARNING: missing Glide installation, assuming no 3Dfx available
----- CL_Shutdown -----
RE_Shutdown( 1 )
GLW_StartOpenGL() - could not load OpenGL subsystem
Merci pour votre aide .
execing default.cfg
QKEY found.
----- R_Init -----
...initializing QGL
...125 PFDs found
...initializing QGL
RE_Shutdown( 1 )
Configuration: Windows 7 Internet Explorer 7.0
C'est les paramètres videos qui débloquent. La version 4.2 n'est pas encore sortie... Tssss
Heuuu on s'en fout de ce qui est écrit dans la console au fait !
il faut que tu configure tes concombres!
En supprimant ou en renommant le dossier de configuration Q3UT4 d'urban terror qui doit se trouver dans document & settings\application data\q3ut4 un truc dans le genre
sur linux c'est un répertoire caché au niveau de son profil: .q3a\q3ut4
en relançant Urban terror, ce dernier va recréer ce dossier, là vous pouvez reconfigurer le jeu, sans trop pousser les paramètres...
Si vous aviez des binds radios ou des funstuff vous pourrez les remettre dans le nouveau répertoire... -
meme probleme que toi ,sa doit etre en beug du logiciel ,ta essayer de te transgrader sur une version inferieur a la 4.2 ?
De l'aide svp
Personne ???!
