Problèm transfert FTP
Bonjour a tout le monde,
Je tente a travers une de mes application de transférer un fichier photo mes il me met permission denied
Par contre quand j'utilise filezilla avec le meme log le transfert s'effectue bien auriez vous une explication svp?
merci d'avance
Configuration: Linux
Firefox 3.0.10
  1. Peut etre que les permision de l'utilisateur "photographe" sont limité juste a la lecture mais pas a l'ecriture
    1. voici le fichier de conf de proftpd
      # /etc/proftpd/proftpd.conf -- This is a basic ProFTPD configuration file.
      # To really apply changes reload proftpd after modifications.
      # Includes DSO modules
      Include /etc/proftpd/modules.conf
      # Set off to disable IPv6 support which is annoying on IPv4 only boxes.
      UseIPv6				off
      ServerName			"Islo people"
      ServerType			standalone
      DeferWelcome			on
      MultilineRFC2228		on
      DefaultServer			on
      ShowSymlinks			on
      TimeoutNoTransfer		600
      TimeoutStalled			600
      TimeoutIdle			1200
      DisplayLogin                    welcome.msg
      DisplayFirstChdir               .message
      ListOptions                	"-l"
      DenyFilter			\*.*/
      # Port 21 is the standard FTP port.
      Port				21
      # In some cases you have to specify passive ports range to by-pass
      # firewall limitations. Ephemeral ports can be used for that, but
      # feel free to use a more narrow range.
      # PassivePorts                    49152 65534
      # To prevent DoS attacks, set the maximum number of child processes
      # to 30.  If you need to allow more than 30 concurrent connections
      # at once, simply increase this value.  Note that this ONLY works
      # in standalone mode, in inetd mode you should use an inetd server
      # that allows you to limit maximum number of processes per service
      # (such as xinetd)
      MaxInstances			30
      Defaultroot			/home/ftp/
      # Set the user and group that the server normally runs at.
      User				proftpd
      Group				nogroup
      # Umask 022 is a good standard umask to prevent new files and dirs
      # (second parm) from being group and world writable.
      Umask				022  022
      # Normally, we want files to be overwriteable.
      AllowOverwrite			on
      # Uncomment this if you are using NIS or LDAP to retrieve passwords:
      # PersistentPasswd		off
      # Be warned: use of this directive impacts CPU average load!
      # Uncomment this if you like to see progress and transfer rate with ftpwho
      # in downloads. That is not needed for uploads rates.
      # UseSendFile			off
      TransferLog /var/log/proftpd/xferlog
      SystemLog   /var/log/proftpd/proftpd.log
      <IfModule mod_tls.c>
      TLSEngine on
      TLSprotocol 				SSLv23
      TLSRSACertificateFile			/etc/proftpd/proftpd.pem
      TLSRSACertificateKeyFile		/etc/proftpd/proftpd.pem
      TLSlog 					/var/log/proftpd/proftpd_SSL.log
      TLSrequired				on
      </IfModule>
      <IfModule mod_quota.c>
      QuotaEngine on
      </IfModule>
      <IfModule mod_ratio.c>
      Ratios on
      </IfModule>
      # Delay engine reduces impact of the so-called Timing Attack described in
      # http://security.lss.hr/index.php?page=details&ID=LSS-2004-10-02
      # It is on by default.
      <IfModule mod_delay.c>
      DelayEngine on
      </IfModule>
      <IfModule mod_ctrls.c>
      ControlsEngine        on
      ControlsMaxClients    2
      ControlsLog           /var/log/proftpd/controls.log
      ControlsInterval      5
      ControlsSocket        /var/run/proftpd/proftpd.sock
      </IfModule>
      <IfModule mod_ctrls_admin.c>
      AdminControlsEngine on
      </IfModule>
      # A basic anonymous configuration, no upload directories.
      # <Anonymous ~ftp>
      #   User				ftp
      #   Group				nogroup
      #   # We want clients to be able to login with "anonymous" as well as "ftp"
      #   UserAlias			anonymous ftp
      #   # Cosmetic changes, all files belongs to ftp user
      #   DirFakeUser	on ftp
      #   DirFakeGroup on ftp
      #   RequireValidShell		off
      #   # Limit the maximum number of anonymous logins
      #   MaxClients			10
      #   # We want 'welcome.msg' displayed at login, and '.message' displayed
      #   # in each newly chdired directory.
      #   DisplayLogin			welcome.msg
      #   DisplayFirstChdir		.message
      #   # Limit WRITE everywhere in the anonymous chroot
      #   <Directory *>
      #     <Limit WRITE>
      #       DenyAll
      #     </Limit>
      #   </Directory>
      #   # Uncomment this if you're brave.
      #   # <Directory incoming>
      #   #   # Umask 022 is a good standard umask to prevent new files and dirs
      #   #   # (second parm) from being group and world writable.
      #   #   Umask				022  022
      #   #            <Limit READ WRITE>
      #   #            DenyAll
      #   #            </Limit>
      #   #            <Limit STOR>
      #   #            AllowAll
      #   #            </Limit>
      #   # </Directory>
      # </Anonymous>
      après les retour quand je tente de me connecté avec l'application que j'ai codé
      SKT <<< 220 ProFTPD 1.3.0 Server ready.
      SKT >>> AUTH TLS
      SKT <<< 234 AUTH TLS successful
      >>> USER photographe
      <<< 331 Password required for photographe.
      >>> PASS *******
      <<< 230-Welcome, archive user photographe@islo.local !
      <<< 230-
      <<< 230-The local time is: Mon Jun  1 18:06:07 2009
      <<< 230-
      <<< 230-This is an experimental FTP server.  If have any unusual problems,
      <<< 230-please report them via e-mail to <root@localhost>.
      <<< 230-
      <<< 230 User photographe logged in.
      >>> PBSZ 0
      <<< 200 PBSZ 0 successful
      >>> PROT P
      <<< 200 Protection set to Private
      >>> PASV
      <<< 227 Entering Passive Mode (10,0,2,69,207,255).
      >>> ALLO 26497
      <<< 202 No storage allocation necessary.
      <<< 550 logo.png: Permission denied
      >>> PBSZ 0
      >>> PROT P
      >>> PASV
      <<< 227 Entering Passive Mode (10,0,2,69,232,129).
      >>> ALLO 191488
      <<< 550 chausiku.JPG: Permission denied
      >>> PBSZ 0
      >>> PROT P
      >>> PASV
      <<< 227 Entering Passive Mode (10,0,2,69,218,68).
      >>> ALLO 37318
      <<< 550 formation_comprendre_raw_54.jpg: Permission denied
      Je ne sais pas si c'est ce que tu veut je pense que oui
      merci d'avance
      1. non mais c'est une application que j'ai codé lol
        C'est pour ca que je me pose la question est ce que ca pourrais venir des droits de l'utilisateur?
        Mais alors pourquoi je peux les transférer avec filezilla?
        1. Le FTP est un protocol de transfert , il n'est pas utiliser par tout les programmes c'est pourquoi des clients ftp existe , simple non ?
