Installation a probleme
bonjour je suis débutant sur linux
j'ai installer red hat sur mon ordinateur et puis j'ai essayé d'installer le logiciel zinf-2.2.5 que j'ai telécharger d'internet sur telecharger.com une foi le programme decompreser je me suis mit en su et j'ai tappé
[root@zqrreur zinf-2.2.5]# ./configure
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking build system type... i686-pc-linux-gnu
checking host system type... i686-pc-linux-gnu
checking whether make sets $(MAKE)... (cached) yes
checking for gm4... no
checking for m4... m4
checking for gcc... no
checking for cc... no
checking for cl... no
configure: error: no acceptable C compiler found in $PATH
See `config.log' for more details.
j'ai regardé config.log comme il est dit mais je ne comprend rien a l'aide
This file contains any messages produced by compilers while
running configure, to aid debugging if configure makes a mistake.
It was created by configure, which was
generated by GNU Autoconf 2.59. Invocation command line was
$ ./configure
## Platform. ##
hostname = zqrreur
uname -m = i686
uname -r = 2.4.20-8
uname -s = Linux
uname -v = #1 Thu Mar 13 17:18:24 EST 2003
/usr/bin/uname -p = unknown
/bin/uname -X = unknown
/bin/arch = i686
/usr/bin/arch -k = unknown
/usr/convex/getsysinfo = unknown
hostinfo = unknown
/bin/machine = unknown
/usr/bin/oslevel = unknown
/bin/universe = unknown
PATH: /usr/local/bin
PATH: /usr/bin
PATH: /bin
PATH: /usr/X11R6/bin
PATH: /home/warreur/bin
## Core tests. ##
configure:1582: checking for a BSD-compatible install
configure:1637: result: /usr/bin/install -c
configure:1648: checking whether build environment is sane
configure:1691: result: yes
configure:1724: checking for gawk
configure:1740: found /usr/bin/gawk
configure:1750: result: gawk
configure:1760: checking whether make sets $(MAKE)
configure:1780: result: yes
configure:2037: checking build system type
configure:2055: result: i686-pc-linux-gnu
configure:2063: checking host system type
configure:2077: result: i686-pc-linux-gnu
configure:2104: checking whether make sets $(MAKE)
configure:2124: result: yes
configure:2138: checking for gm4
configure:2167: result: no
configure:2138: checking for m4
configure:2154: found /usr/bin/m4
configure:2164: result: m4
configure:2221: checking for gcc
configure:2250: result: no
configure:2301: checking for cc
configure:2330: result: no
configure:2343: checking for cc
configure:2389: result: no
configure:2442: checking for cl
configure:2471: result: no
configure:2485: error: no acceptable C compiler found in $PATH
## Cache variables. ##
ac_cv_build=i686-pc-linux-gnu
ac_cv_build_alias=i686-pc-linux-gnu
ac_cv_env_CC_set=
ac_cv_env_CC_value=
ac_cv_env_CFLAGS_set=
ac_cv_env_CFLAGS_value=
ac_cv_env_CPPFLAGS_set=
ac_cv_env_CPPFLAGS_value=
ac_cv_env_CPP_set=
ac_cv_env_CPP_value=
ac_cv_env_CXXCPP_set=
ac_cv_env_CXXCPP_value=
ac_cv_env_CXXFLAGS_set=
ac_cv_env_CXXFLAGS_value=
ac_cv_env_CXX_set=
ac_cv_env_CXX_value=
ac_cv_env_F77_set=
ac_cv_env_F77_value=
ac_cv_env_FFLAGS_set=
ac_cv_env_FFLAGS_value=
ac_cv_env_LDFLAGS_set=
ac_cv_env_LDFLAGS_value=
ac_cv_env_build_alias_set=
ac_cv_env_build_alias_value=
ac_cv_env_host_alias_set=
ac_cv_env_host_alias_value=
ac_cv_env_target_alias_set=
ac_cv_env_target_alias_value=
ac_cv_host=i686-pc-linux-gnu
ac_cv_host_alias=i686-pc-linux-gnu
ac_cv_path_install='/usr/bin/install -c'
ac_cv_prog_AWK=gawk
ac_cv_prog_M4=m4
ac_cv_prog_make_make_set=yes
## Output variables. ##
ACLOCAL='${SHELL} /home/warreur/zinf-2.2.5/config/missing --run aclocal-1.7'
ALLOCA=''
ALSA_CFLAGS=''
ALSA_LIBS=''
AMDEPBACKSLASH=''
AMDEP_FALSE=''
AMDEP_TRUE=''
AMTAR='${SHELL} /home/warreur/zinf-2.2.5/config/missing --run tar'
AR=''
ARTSCCONFIG=''
ARTS_CFLAGS=''
ARTS_LIBS=''
AUTOCONF='${SHELL} /home/warreur/zinf-2.2.5/config/missing --run autoconf'
AUTOHEADER='${SHELL} /home/warreur/zinf-2.2.5/config/missing --run autoheader'
AUTOMAKE='${SHELL} /home/warreur/zinf-2.2.5/config/missing --run automake-1.7'
AWK='gawk'
BOOST_LIBS=''
CC=''
CCDEPMODE=''
CFLAGS=''
CPP=''
CPPFLAGS=''
CXX=''
CXXCPP=''
CXXDEPMODE=''
CXXFLAGS=''
CYGPATH_W='echo'
DEFS=''
DEPDIR=''
DMALLOCLIB=''
ECHO='echo'
ECHO_C=''
ECHO_N='-n'
ECHO_T=''
EGREP=''
ESD_CFLAGS=''
ESD_CONFIG=''
ESD_LIBS=''
EXEEXT=''
F77=''
FFLAGS=''
FTC_PLUGINS=''
GDBM_CFLAGS=''
GDBM_LIBS=''
GLIB_CFLAGS=''
GLIB_GENMARSHAL=''
GLIB_LIBS=''
GLIB_MKENUMS=''
GMSGFMT=''
GOBJECT_QUERY=''
GTKMM_CFLAGS=''
GTKMM_LIBS=''
GTK_CFLAGS=''
GTK_LIBS=''
ID3LIB_CFLAGS=''
ID3LIB_LIBS=''
INSTALL_DATA='${INSTALL} -m 644'
INSTALL_PROGRAM='${INSTALL}'
INSTALL_SCRIPT='${INSTALL}'
INSTALL_STRIP_PROGRAM='${SHELL} $(install_sh) -c -s'
INTLLIBS=''
IO_PLUGINS=''
LDFLAGS=''
LIBICONV=''
LIBINTL=''
LIBOBJS=''
LIBS=''
LIBTOOL=''
LIBXOSD_CFLAGS=''
LIBXOSD_CONFIG=''
LIBXOSD_LIBS=''
LMC_PLUGINS=''
LN_S=''
LTLIBICONV=''
LTLIBINTL=''
LTLIBOBJS=''
M4='m4'
MAKEINFO='${SHELL} /home/warreur/zinf-2.2.5/config/missing --run makeinfo'
MDB=''
METADATA_PLUGINS=''
MKINSTALLDIRS=''
MSGFMT=''
MSGMERGE=''
MUSICBRAINZ_CFLAGS=''
MUSICBRAINZ_LIBS=''
NASM=''
NCURSES_CFLAGS=''
NCURSES_LIBS=''
OBJEXT=''
ORBIT_CFLAGS=''
ORBIT_CONFIG=''
ORBIT_IDL=''
ORBIT_LIBS=''
PACKAGE='zinf'
PACKAGE_BUGREPORT=''
PACKAGE_NAME=''
PACKAGE_STRING=''
PACKAGE_TARNAME=''
PACKAGE_VERSION=''
PATH_SEPARATOR=':'
PERL=''
PKG_CONFIG=''
PORTABLE_PLUGINS=''
POSUB=''
PTHREAD_CFLAGS=''
PTHREAD_LIBS=''
RANLIB=''
SET_MAKE=''
SHELL='/bin/sh'
STRIP=''
THREAD_CFLAGS=''
THREAD_LIBS=''
UI_PLUGINS=''
UNIX_AUDIO_API=''
USE_NLS=''
VERSION='2.2.5'
VORBISENC_LIBS=''
VORBISFILE_LIBS=''
VORBIS_CFLAGS=''
VORBIS_LIBS=''
XGETTEXT=''
XINGASM=''
ZINF_HOST_OS=''
ZINF_LIBS=''
ZINF_OS_UNIX_FALSE=''
ZINF_OS_UNIX_TRUE=''
ZINF_OS_WIN32_FALSE=''
ZINF_OS_WIN32_TRUE=''
ZLIB_CFLAGS=''
ZLIB_LIBS=''
ac_ct_AR=''
ac_ct_CC=''
ac_ct_CXX=''
ac_ct_F77=''
ac_ct_RANLIB=''
ac_ct_STRIP=''
am__fastdepCC_FALSE=''
am__fastdepCC_TRUE=''
am__fastdepCXX_FALSE=''
am__fastdepCXX_TRUE=''
am__include=''
am__leading_dot='.'
am__quote=''
bindir='${exec_prefix}/bin'
build='i686-pc-linux-gnu'
build_alias=''
build_cpu='i686'
build_os='linux-gnu'
build_vendor='pc'
datadir='${prefix}/share'
exec_prefix='NONE'
host='i686-pc-linux-gnu'
host_alias=''
host_cpu='i686'
host_os='linux-gnu'
host_vendor='pc'
includedir='${prefix}/include'
infodir='${prefix}/info'
install_sh='/home/warreur/zinf-2.2.5/config/install-sh'
libdir='${exec_prefix}/lib'
libexecdir='${exec_prefix}/libexec'
localstatedir='${prefix}/var'
mandir='${prefix}/man'
oldincludedir='/usr/include'
prefix='NONE'
program_transform_name='s,x,x,'
sbindir='${exec_prefix}/sbin'
sharedstatedir='${prefix}/com'
sysconfdir='${prefix}/etc'
target_alias=''
## confdefs.h. ##
#define BRANDING "Zinf"
#define BRANDING_APP_NAME "zinf"
#define BRANDING_COMPANY "Zinf"
#define BRANDING_DEFAULT_THEME "Zinf.fat"
#define BRANDING_SHARE_PATH "/../share/zinf"
#define BRANDING_UPDATE_PATH "/update/zinf"
#define BRANDING_UPDATE_SERVER "www.zinf.org"
#define BRANDING_URL "http://www.zinf.org"
#define BRANDING_VERSION "2.2.5"
#define HOST_CPU "i686"
#define HOST_OS "linux-gnu"
#define PACKAGE "zinf"
#define PACKAGE_BUGREPORT ""
#define PACKAGE_NAME ""
#define PACKAGE_STRING ""
#define PACKAGE_TARNAME ""
#define PACKAGE_VERSION ""
#define The_BRANDING "Zinf"
#define VERSION "2.2.5"
#define ZINF_PATH_ENV "ZINF_PATH"
#define ZINF_VERSION "2.2.5"
#define the_BRANDING "Zinf"
configure: exit 1
merci de votre aide
$ ./configure
## Platform. ##
hostname = zqrreur
uname -m = i686
uname -r = 2.4.20-8
uname -s = Linux
/bin/arch = i686
hostinfo = unknown
PATH: /usr/bin
PATH: /bin
## Core tests. ##
ac_cv_env_CC_set=
ac_cv_env_CC_value=
ac_cv_env_CPP_set=
ac_cv_env_CXX_set=
ac_cv_env_F77_set=
ac_cv_prog_AWK=gawk
ac_cv_prog_M4=m4
ALLOCA=''
ALSA_CFLAGS=''
ALSA_LIBS=''
AMDEPBACKSLASH=''
AMDEP_FALSE=''
AMDEP_TRUE=''
AR=''
ARTSCCONFIG=''
ARTS_CFLAGS=''
ARTS_LIBS=''
AWK='gawk'
BOOST_LIBS=''
CC=''
CCDEPMODE=''
CFLAGS=''
CPP=''
CPPFLAGS=''
CXX=''
CXXCPP=''
CXXDEPMODE=''
CXXFLAGS=''
CYGPATH_W='echo'
DEFS=''
DEPDIR=''
DMALLOCLIB=''
ECHO='echo'
ECHO_C=''
ECHO_N='-n'
ECHO_T=''
EGREP=''
ESD_CFLAGS=''
ESD_CONFIG=''
ESD_LIBS=''
EXEEXT=''
F77=''
FFLAGS=''
FTC_PLUGINS=''
GDBM_CFLAGS=''
GDBM_LIBS=''
GLIB_CFLAGS=''
GLIB_GENMARSHAL=''
GLIB_LIBS=''
GLIB_MKENUMS=''
GMSGFMT=''
GOBJECT_QUERY=''
GTKMM_CFLAGS=''
GTKMM_LIBS=''
GTK_CFLAGS=''
GTK_LIBS=''
ID3LIB_CFLAGS=''
ID3LIB_LIBS=''
INTLLIBS=''
IO_PLUGINS=''
LDFLAGS=''
LIBICONV=''
LIBINTL=''
LIBOBJS=''
LIBS=''
LIBTOOL=''
LIBXOSD_CFLAGS=''
LIBXOSD_CONFIG=''
LIBXOSD_LIBS=''
LMC_PLUGINS=''
LN_S=''
LTLIBICONV=''
LTLIBINTL=''
LTLIBOBJS=''
M4='m4'
MDB=''
METADATA_PLUGINS=''
MKINSTALLDIRS=''
MSGFMT=''
MSGMERGE=''
MUSICBRAINZ_LIBS=''
NASM=''
NCURSES_CFLAGS=''
NCURSES_LIBS=''
OBJEXT=''
ORBIT_CFLAGS=''
ORBIT_CONFIG=''
ORBIT_IDL=''
ORBIT_LIBS=''
PACKAGE='zinf'
PACKAGE_NAME=''
PACKAGE_STRING=''
PACKAGE_TARNAME=''
PACKAGE_VERSION=''
PATH_SEPARATOR=':'
PERL=''
PKG_CONFIG=''
PORTABLE_PLUGINS=''
POSUB=''
PTHREAD_CFLAGS=''
PTHREAD_LIBS=''
RANLIB=''
SET_MAKE=''
SHELL='/bin/sh'
STRIP=''
THREAD_CFLAGS=''
THREAD_LIBS=''
UI_PLUGINS=''
UNIX_AUDIO_API=''
USE_NLS=''
VERSION='2.2.5'
VORBISENC_LIBS=''
VORBISFILE_LIBS=''
VORBIS_CFLAGS=''
VORBIS_LIBS=''
XGETTEXT=''
XINGASM=''
ZINF_HOST_OS=''
ZINF_LIBS=''
ZLIB_CFLAGS=''
ZLIB_LIBS=''
ac_ct_AR=''
ac_ct_CC=''
ac_ct_CXX=''
ac_ct_F77=''
ac_ct_RANLIB=''
ac_ct_STRIP=''
am__include=''
am__leading_dot='.'
am__quote=''
build_alias=''
build_cpu='i686'
build_vendor='pc'
exec_prefix='NONE'
host_alias=''
host_cpu='i686'
host_os='linux-gnu'
host_vendor='pc'
prefix='NONE'
target_alias=''
## confdefs.h. ##
configure: exit 1
merci de votre aide
bonjour,
De plus, on peut rajouter qu'avant de lancer la commande ./configure, il convient de lire les fichiers INSTALL, README ou HOWTO contenus dans les archives décompressées.
On y trouve les options qui permettent de surmonter un grand nombre de problèmes d'installation.
Et puis c'est l'occasion de revoir son anglais... -
En Mandrake il faut bien completer apres l'installation avec de paquets *rpm sur de sites ftp. Pour details voir mon poste de cette nuit:
http://www.commentcamarche.net/forum/affich-1242240#17
Si on veut faire de trucs avec de paquets sources.tar.gz il faut:
(1) Installer tous les compilateurs gcc, g++, ... aussi les binutils (c'est imperatif!)
(2) utilitaires comme "perl", "sed", "make", "m4", "bison", .... il y en a pleins, normalement dans une bonne distribution ca doit etre automatique. Pour ca Mandrake n'est pas tres bon (en Fedora c'est plus facile de ne pas oublier ces choses cruciales).
(3) Les bibliotheques en versions developpement, sur les cd il n'y a que les versions runtime, ca ne permet pas de compiler de programes utilisant ces bibiliotheques. Il faut completer par ftp, ca concerne Xorg, qt, kde, et pleins de trucs!!
(4) Si on veut installer de drivers (modems, scanneurs, ...) a partir des sources qui sont de modules noyaux il faut aussi installer le "kernel-source-2.6.8.1.....rpm" !!!
Donc je te conseilles de rajouter de sites ftp dans le menu installation software de drakconf (voir le lien ci-dessus) et completer au mieux! -
ContributeurSalut,
Juste pour savoir, pourquoi tu n'installe pas le rpm? ça m'a l'aire nettement plus simple.
Renisaac -
ModérateurSalut,
Ton problème il est là, tu n'as pas de "complier", rajoutes-le dans la gestion des paquetages sous RedHat, en gros rajoutes toutes la partie "Dévellopement".
Z'@+...che.JP : Zen, my Nuggets ! ;-) sh:/bin/laden: Not found !
