R4 ds lite multiplayer issues help me help
Hello everyone
I have a problem with my R4 when I want to play a DS card in multiplayer, it works fine with Mario at the Olympic Games, but with Mario Kart it crashes when the game is about to start, and Call of Duty used to work but doesn't anymore. Can you tell me why? Thank you.
  • Descending date
  1. Hello everyone,
    To address your issues (assuming you have the original games otherwise it would be illegal):
    For multiplayer => You need to use the trimmer found here on the ROMs:
    http://www.r4ds.com/soft/1-other-en.htm
    For the error message => Download the archive and extract it onto the memory card
    http://www.r4ds.com/soft/english2/French-1.18.rar
    or
    http://download.r4ds.com/soft/english2/French-1.18.rar
    That's it.
    Be careful not to fall into illegality ;)
    PS: Do not trim ROMs that are already trimmed as they probably won't start!
    1. I have the same problem with my linker; certain ROMs do not work in multiplayer mode :(
      If anyone knows the solution :)
      1. I also bought an R4 card with a 2 GB micro SD card and everything works well. The problem is that I wanted to buy another 2 GB micro SD card from a supermarket and I put games on it, but when I insert it into the DS, I get the following message: couldn't find DS MENU.DAT. Thank you for your help.
