Battery plugged in, not charging
moiza Posted messages 61 Status Member -
Hello,
device Schneider SCL141CTP
very little used, a gift
battery problem 61 percent available not charging? it stays really at 61 percent.
to know that I am in full campaign I operate with a 3G key and everything runs on a generator set
thank you for your help
  1. Fivel51 Posted messages 510 Status Member 152
    Hi,
    did you reboot it? If yes, it stays blocked at 61% battery? But if you use it, it goes down, right? And when you recharge it, it never goes higher than 61%?
    3
    1. moiza Posted messages 61 Status Member
      I will try, thank you.
    2. moiza Posted messages 61 Status Member
      half an hour later still 61 percent and 3h 34 of autonomy there I am obliged to stop and more and again thank you
