Turn on an LED by clapping using a microphone
Hello, as a beginner, I'm asking for your help. My goal is to be able to turn on an LED using a microphone by clapping my hands, and then turn it off by clapping my hands again. How is it possible to do this?
Thank you in advance.
  1. Contributor
    Hey, it all depends on the platform you're using and the equipment you have available...
    By the way, hello again! It's been a while ;)
    from human import idiocy
    del idiocy
    1. Hello again :D
      Yes, I only have an Arduino UNO.... But I have a microphone (a must..)
  2. Contributor
    Well, first you put your LED on the Arduino (obviously), connected to a pin (e.g. 13) and to GND -- with an appropriate resistor so as not to blow the diode.
    For your microphone, it needs to be connected to an ANALOG IN pin as well as GND;
    However, we have no indication of the voltage amplitude it can provide, and it will likely need to be amplified.
    On the code side, you will need to:
    - set up the ADC so that we can read the audio data, ideally at 22kHz (or higher)
    - have a variable to know whether to turn the LED on or off
    - in a loop, read the analog data, and if a spike is detected, toggle the state of the LED
    For the state variable, it's trivial:
    bool ledAllumee = false;
    For ADC initialization, it’s less straightforward... because analogRead allows for a maximum of 10,000 reads per second.
    You will also need to determine what the voltage is when a clap occurs, which should be much higher than the ambient noise.
    del idiocy
    1. Okay, so for now, I've written this code:
      const int m1 = 7; void setup() { //initialization content pinMode(m1, OUTPUT); } void loop() { digitalWrite(m1, HIGH);}
      It's not lighting up an LED but a relay (For a home automation project).
      What I think I need to do first:
       const int m1 = 7; const int mic =8; void setup() { pinMode(mic, INPUT); pinMode(m1, OUTPUT); } void loop() { digitalWrite(m1, HIGH);}
      And add conditions:
      if
      else
      But I don't know how to go about it.. After that, I have to know that the code runs in a loop, so it refreshes automatically, and has to detect exactly when the microphone sends something.
