Splitting a Word page into 3 exact parts
Christelle -
BmV Posted messages 43795 Registration date   Status Moderator Last intervention   -
Hello,
I am looking for how to divide my Word page into three exact parts (lines) and how to put small marks on the side to make it easier to cut later.
Thank you for your help.
Configuration: Windows 7 / Internet Explorer 8.0
  1. BmV Posted messages 43795 Registration date   Status Moderator Last intervention   4 975
    Hi,
    Create a table with three rows and a single column, measuring 9.99 cm high and 21 cm wide, centered.
    For the marks on the side, you can create a second column that is 1 cm wide, for example (the other will therefore only be 20 cm wide), either on one side of your page, the other, or both (adjust the dimensions accordingly); in this thin column, you will add a border, but only on the horizontal side, and you will then have your cutting guides..
    -=O(_BmV_)O=-
    &nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp "A clean tie inevitably attracts food." -Murphy's Law-
    4
