My PC switches to power saving mode.
mariela6
mariela6 -
mariela6 -
Hello,
my Athlon processor 3500+ PC goes into "power-saving mode" before WINDOWS XP has fully started.
I have changed the monitor and the cable, and the problem persists.
If I start in "safe mode with networking," the PC does not go into "power-saving mode."
What should I do to work normally?
Thank you.
Thank you.
Thank you for the response.
I should point out that it's a desktop PC, so there's no battery issue.
For now, I'm working in "safe mode with networking." Too bad about the display.
I don't know if it's a coincidence, but the problem started after unplugging the monitor cable while the PC was running...
Thank you for your advice.
