Probleme apres l'installation de linux
Je viens d'installer Ubuntu 8.04 en cojabition avec XP. J'ai du faire une betise pendant l'installation parce que, au moment de choisir le systeme d'exploitation (au demarrage de l'ordi), il y a 2 fois le meme choix pour linux et 2 fois le choix pour recovery mode ?
Est ce que quelqu'un sais si je peux en supprimer, et si oui comment je dois faire ?
Configuration: Linux Firefox 3.0
Contributeurbonjour,
donne nous le resultat de
ouvre une console et tapes
sudo cat /boot/grub/menu.lst
a+
# menu.lst - See: grub(8), info grub, update-grub(8)
# grub-install(8), grub-floppy(8),
# grub-md5-crypt, /usr/share/doc/grub
# and /usr/share/doc/grub-doc/.
## default num
# Set the default entry to the entry number NUM. Numbering starts from 0, and
# the entry number 0 is the default if the command is not used.
# You can specify 'saved' instead of a number. In this case, the default entry
# is the entry saved with the command 'savedefault'.
# WARNING: If you are using dmraid do not use 'savedefault' or your
# array will desync and will not let you boot your system.
default 0
## timeout sec
# Set a timeout, in SEC seconds, before automatically booting the default entry
# (normally the first entry defined).
timeout 10
## hiddenmenu
# Hides the menu by default (press ESC to see the menu)
#hiddenmenu
# Pretty colours
#color cyan/blue white/blue
## password ['--md5'] passwd
# If used in the first section of a menu file, disable all interactive editing
# control (menu entry editor and command-line) and entries protected by the
# command 'lock'
# e.g. password topsecret
# password --md5 $1$gLhU0/$aW78kHK1QfV3P2b2znUoe/
# password topsecret
# examples
# title Windows 95/98/NT/2000
# root (hd0,0)
# makeactive
# chainloader +1
# title Linux
# root (hd0,1)
# kernel /vmlinuz root=/dev/hda2 ro
# Put static boot stanzas before and/or after AUTOMAGIC KERNEL LIST
### BEGIN AUTOMAGIC KERNELS LIST
## lines between the AUTOMAGIC KERNELS LIST markers will be modified
## by the debian update-grub script except for the default options below
## DO NOT UNCOMMENT THEM, Just edit them to your needs
## ## Start Default Options ##
## default kernel options
## default kernel options for automagic boot options
## If you want special options for specific kernels use kopt_x_y_z
## where x.y.z is kernel version. Minor versions can be omitted.
## e.g. kopt=root=/dev/hda1 ro
## kopt_2_6_8=root=/dev/hdc1 ro
## kopt_2_6_8_2_686=root=/dev/hdc2 ro
# kopt=root=UUID=96f2a096-ceea-4131-b250-db521d7b51b1 ro
## Setup crashdump menu entries
## e.g. crashdump=1
# crashdump=0
## default grub root device
## e.g. groot=(hd0,0)
# groot=(hd1,0)
## should update-grub create alternative automagic boot options
## e.g. alternative=true
## alternative=false
# alternative=true
## should update-grub lock alternative automagic boot options
## e.g. lockalternative=true
## lockalternative=false
## additional options to use with the default boot option, but not with the
## alternatives
## e.g. defoptions=vga=791 resume=/dev/hda5
# defoptions=quiet splash
## should update-grub lock old automagic boot options
## e.g. lockold=false
## lockold=true
# lockold=false
## Xen hypervisor options to use with the default Xen boot option
# xenhopt=
## Xen Linux kernel options to use with the default Xen boot option
# xenkopt=console=tty0
## altoption boot targets option
## multiple altoptions lines are allowed
## e.g. altoptions=(extra menu suffix) extra boot options
## altoptions=(recovery) single
# altoptions=(recovery mode) single
## controls how many kernels should be put into the menu.lst
## only counts the first occurence of a kernel, not the
## alternative kernel options
## e.g. howmany=all
## howmany=7
# howmany=all
## should update-grub create memtest86 boot option
## e.g. memtest86=true
## memtest86=false
# memtest86=true
## should update-grub adjust the value of the default booted system
## can be true or false
# updatedefaultentry=false
## should update-grub add savedefault to the default options
# savedefault=false
## ## End Default Options ##
title Ubuntu 8.04, kernel 2.6.24-18-generic
root (hd1,0)
kernel /boot/vmlinuz-2.6.24-18-generic root=UUID=96f2a096-ceea-4131-b250-db521d7b51b1 ro quiet splash
initrd /boot/initrd.img-2.6.24-18-generic
quiet
title Ubuntu 8.04, kernel 2.6.24-18-generic (recovery mode)
root (hd1,0)
kernel /boot/vmlinuz-2.6.24-18-generic root=UUID=96f2a096-ceea-4131-b250-db521d7b51b1 ro single
title Ubuntu 8.04, kernel 2.6.24-16-generic
root (hd1,0)
kernel /boot/vmlinuz-2.6.24-16-generic root=UUID=96f2a096-ceea-4131-b250-db521d7b51b1 ro quiet splash
initrd /boot/initrd.img-2.6.24-16-generic
quiet
title Ubuntu 8.04, kernel 2.6.24-16-generic (recovery mode)
root (hd1,0)
kernel /boot/vmlinuz-2.6.24-16-generic root=UUID=96f2a096-ceea-4131-b250-db521d7b51b1 ro single
title Ubuntu 8.04, memtest86+
root (hd1,0)
kernel /boot/memtest86+.bin
quiet
### END DEBIAN AUTOMAGIC KERNELS LIST
# This is a divider, added to separate the menu items below from the Debian
# ones.
title Other operating systems:
root
# This entry automatically added by the Debian installer for a non-linux OS
# on /dev/sda1
title Microsoft Windows XP dition familiale
root (hd0,0)
savedefault
makeactive
chainloader +1 -
tu n'a pas fait d'erreur , simplement tu as fait une mise à jour de ton kernel donc tu as le choix de booter soit sur l'ancien ou le nouveau kernel.
tu peux supprimer les lignes correspondant à title Ubuntu 8.04, kernel 2.6.24-16-generic .
mais il serait bon de supprimer le kernel avec synaptic c'est plus propre .
a+
ok merci
