Help my computer,svp
My computer is often died, it is windows xp sp2, no virus, what's wrong?
Sometimes, when I restart, and look bios,it will die too, but the company who say it is no problem........ I am sad.I don't know why!
Good Nike,Puma,Lacoste, D&G....www.jjsneaker.com
Internet Explorer 6.0
13 réponses
  1. Hi,ok,
    just now, it need to restart, only work 10 minutes,have no virus, soon my friend come, to check the mainboard, hope he can find the problem,
    Tout à l'heure, il faut redémarrer, seuls les travaux de 10 minutes, N'ont pas de virus, mon ami bientôt venir, pour vérifier la carte mère, de l'espoir, il peut m'aider,
    1. I don't think your probleme is coming from the motherboard.
      Since when you have this problem ?
      1. Hi,2 weeks ago, the problem came, in right words, it calls "The PC is frozen!"... it can work well about 10 minute, then freeze, I need to reset,
        I hope someone can understand my mean, sorry for my english, I search the reason on google,
        PS:this morning,I take the PC to computer company,it is ok for 30 minutes , it don't be frizen, then the worker say nothing, and I take it back, at home, it happen.
        1. Try a restoration of your system to another date
          1. Hi MoKo, I think it is hardware problem, because yesterday I re-install the XP, it happens too, that's why thismorning I take to computer company, but they can't help, so now I called my friend, and post here,
        2. Hi, I click these link, but the second link,I can't open, thank you still,
          my friend don't know why too, I think tomorrow I will take to computer company, to check again,hope then it is frozen there, so sad.
          1. Hi, my computer is ok now,
            just this, the fan for CPU runs slowly, thus CPU is too hot, , now I change the fan, the problem is solved, thanks everyone. I am happy!
            1. ok have you made a scan file antivirus ?
              Choose INTERNET EXPLORER for the scan, and accept the active x
              surf here =>http://support.f-secure.com/enu/home/ols.shtml
              REad 1 and 2 and 3 and 3. Start your scan
              When you start F-Secure Online Virus Scanner, it will prompt you to accept the certificate and the license terms to install the tool.
              Start the scan by clicking this button: Start scanning
              This is up to you...
              1. Hi, espion3004
                My computer is ok, the problem is cpu fan running slowly, now good:) thank you.
                with your this tool, Online Virus Scanner, I find two virus, thank you again. My antivirus software can't find with the virus..., I will tell my friend this tools^^
