Probleme avec kopete
Je viens d'installer recemment kubuntu 7.10 ,et je viens d'essayé de lancer kopete mais il a bugger
"en raison du signal 11 (SIGSEGV)"
(no debugging symbols found)
Using host libthread_db library "/lib/tls/i686/cmov/libthread_db.so.1".
[Thread debugging using libthread_db enabled]
[New Thread -1241617936 (LWP 7346)]
[KCrash handler]
#6 0xb5a8e11a in MSNAccount::slotNotifySocketClosed ()
from /usr/lib/libkopete_msn_shared.so.0
#7 0xb5a96668 in MSNAccount::qt_invoke ()
#8 0xb6886893 in QObject::activate_signal () from /usr/lib/libqt-mt.so.3
#9 0xb6887338 in QObject::activate_signal () from /usr/lib/libqt-mt.so.3
#10 0xb5a9f8dc in MSNSocket::socketClosed ()
#11 0xb5ab34cd in MSNNotifySocket::disconnect ()
#12 0xb5aaff3b in MSNNotifySocket::sslLoginFailed ()
#13 0xb5ab60f5 in MSNNotifySocket::qt_invoke ()
#14 0xb6886893 in QObject::activate_signal () from /usr/lib/libqt-mt.so.3
#15 0xb6887338 in QObject::activate_signal () from /usr/lib/libqt-mt.so.3
#16 0xb5ad016c in MSNSecureLoginHandler::loginFailed ()
#17 0xb5ad040f in MSNSecureLoginHandler::slotTweenerReceived ()
#18 0xb5ad15a6 in MSNSecureLoginHandler::qt_invoke ()
#19 0xb6886893 in QObject::activate_signal () from /usr/lib/libqt-mt.so.3
#20 0xb74c1021 in KIO::Job::result () from /usr/lib/libkio.so.4
#21 0xb75198cd in KIO::Job::emitResult () from /usr/lib/libkio.so.4
#22 0xb7519d2e in KIO::SimpleJob::slotFinished () from /usr/lib/libkio.so.4
#23 0xb751a43d in KIO::TransferJob::slotFinished () from /usr/lib/libkio.so.4
#24 0xb7519301 in KIO::SimpleJob::qt_invoke () from /usr/lib/libkio.so.4
#25 0xb7519363 in KIO::TransferJob::qt_invoke () from /usr/lib/libkio.so.4
#26 0xb6886893 in QObject::activate_signal () from /usr/lib/libqt-mt.so.3
#27 0xb6c128ec in QSignal::signal () from /usr/lib/libqt-mt.so.3
#28 0xb68a6842 in QSignal::activate () from /usr/lib/libqt-mt.so.3
#29 0xb68ae258 in QSingleShotTimer::event () from /usr/lib/libqt-mt.so.3
#30 0xb681daf0 in QApplication::internalNotify () from /usr/lib/libqt-mt.so.3
#31 0xb681f91f in QApplication::notify () from /usr/lib/libqt-mt.so.3
#32 0xb6fe3ca2 in KApplication::notify () from /usr/lib/libkdecore.so.4
#33 0xb67b0209 in QApplication::sendEvent () from /usr/lib/libqt-mt.so.3
#34 0xb681053b in QEventLoop::activateTimers () from /usr/lib/libqt-mt.so.3
#35 0xb67c4d49 in QEventLoop::processEvents () from /usr/lib/libqt-mt.so.3
#36 0xb68381ce in QEventLoop::enterLoop () from /usr/lib/libqt-mt.so.3
#37 0xb6837fde in QEventLoop::exec () from /usr/lib/libqt-mt.so.3
#38 0xb681f699 in QApplication::exec () from /usr/lib/libqt-mt.so.3
#39 0x0807f95c in ?? ()
#40 0xbfe3c034 in ?? ()
#41 0xbfe3c02c in ?? ()
#42 0xbfe3c024 in ?? ()
#43 0x00000000 in ?? ()
Voila ce qu'il me met dans le Backtrace.Si quelqu'un a deja eu le probleme et a su le resoudre ca serait sympa de ma filler un coup de main .D'avance merci.
Configuration: Linux
Konqueror 3.5
    Je pense qu'une petite mise à jour s'impose :
    sudo aptitude update
    sudo aptitude upgrade
    sudo aptitude reinstall kopete
    Bonne chance
    1. Salut
      Volia j'ai le meme message d'erreur que Bird
      et je vien d'effectuer les mise a jours comme tu le dit precédement mais malgré cela, il me met tjr le meme mesage d'erreur :'(
      S'aurais tu comment regler le probleme
      Ps: j'utilise KUBUNTU 7.0 (depuis 1semaines donc je suis un vrais debutant =S )
      Merci d'avance
  2. Modérateur
    1) Bon on va passer en mode subtil. D'abord on dégage complètement kopete (dpkg vire plus de truc que aptitude en l'occurrence), on fait une mise à jour par acquis de conscience, et on installe deborphan :
    sudo dpkg --purge kopete
    sudo aptitude safe-upgrade
    sudo aptitude install deborphan
    Avec deborphan on va dégager les paquets cassés. Tant que la commande :
    deborphan
    retourne des paquets, tape :
    deborphan | xargs sudo dpkg --purge
    2) Selon que tu veux sauvegarder tes paramètres kopete ou pas suis l'étape 2)a) ou 2)b)
    a) On dégage les fichiers kopete
    rm ~/.kde/share/config/kopeterc
    rm ~/.kde/share/config/kopete.eventsrc
    rm ~/.kde/share/apps/kopete
    b) On va mettre de côté tes paramètres kopete car ce sont peut être eux qui posent problèmes :
    mv ~/.kde/share/config/kopeterc ~/.kde/share/config/kopeterc.old
    mv ~/.kde/share/config/kopete.eventsrc ~/.kde/share/config/kopete.eventsrc.old
    mv ~/.kde/share/apps/kopete ~/.kde/share/apps/kopete.old
    3) Ensuite on réinstalle kopete :
    sudo aptitude install kopete
    4) Si ça ne marche toujours pas donne moi le résultat de :
    cat /etc/apt/sources.list
    dpkg -l | grep kopete
    Bonne chance
