PC ne repond pas
I am using Compaq Evo D510 SFF.
I have removed the Hard Disk from the PC to make back up after that I put the Hard Disk back then it has stopped working.
It is not booting with the Operating CD at all.
These is the Two error messages that showing:
PXE-E61: Media Test Failure, Check Cable.
PXE-MOF: Existing Intel PXE ROM.
It is also starting with Two BEEPS when booting
I have replaced the Hard Disk and the cable to the Hard disk but still
If you press F10 you will just see a blinking on Black Screen, and you can not access the Set up Utilities
But if you removed the Hard Disk, it can allow you Set up Utility.
I need your help.
  1. bjr
    i don't know if you understand french.
    alors.
    en premier et avant toute manipulation matérielle,ENTRER dans le bios et configurer le par défaut.
    je pense que c'est une erreur dans la séquence de démarrage.
    good luck
