Probleme avec firefox
Bonjour, voila j'ai un petit soucis avec firefox ...
en effet je l'ai desinstaller suite a un bug sur la 3.6 , je supprime grace a un sudo apt-get remove firefox3.6 il ne trouve rien ... or que si je fait un sudo apt-cache search firefox il me sort les paquet suivant :
firefox-gnome-support-dbg - firefox gnome support debug symbols
firefox-gnome-support - Support for GNOME in Mozilla Firefox
firefox-dev - Development files for Mozilla Firefox
firefox-dbg - firefox debug symbols
firefox-branding - Package that ships the firefox branding
firefox - safe and easy web browser from Mozilla
firefox-3.6-gnome-support-dbg - firefox-3.6 debug symbols
firefox-3.6-dbg - firefox-3.6 debug symbols
firefox-3.2-gnome-support - dummy upgrade package for firefox-3.2 -> firefox-3.6
firefox-3.2-dev - dummy upgrade package for firefox-3.2 -> firefox-3.6
firefox-3.2-dbg - dummy upgrade package for firefox-3.2 -> firefox-3.6
firefox-3.2-branding - dummy upgrade package for firefox-3.2 -> firefox-3.6
firefox-3.2 - dummy upgrade package for firefox-3.2 -> firefox-3.6
abrowser-3.2-branding - dummy upgrade package for firefox-3.2 -> firefox-3.6
abrowser-3.2 - dummy upgrade package for firefox-3.2 -> firefox-3.6
firefox-3.6 - special transitional package for ffox 3.6 daily users
firefox-3.6-branding - special transitional package for ffox 3.6 daily users
firefox-3.6-dev - special transitional package for ffox 3.6 daily users
firefox-3.6-gnome-support - special transitional package for ffox 3.6 daily users
et si je fait apt-cache search firefox-3.7 il me trouve
shuya@Ivalice:~$ sudo apt-cache search firefox-3.7
firefox-3.7-gnome-support-dbg - firefox-3.7 debug symbols
firefox-3.7-gnome-support - Support for GNOME in Mozilla Firefox
firefox-3.7-dev - Development files for Mozilla Firefox
firefox-3.7-dbg - firefox-3.7 debug symbols
firefox-3.7-branding - Package that ships the firefox branding
firefox-3.7 - safe and easy web browser from Mozilla
Que faire pour tout supprimer ? merci d'avance .
Configuration: firefox 2.O.14
11 réponses
Et en mode graphique ?
Plutôt de te prendre la tête. -
quand je me met avec le gestionnaire de paquet il me dit qu'aucun paquet est installé ....
*or j'arrive a lancer firefox .... -
ubuntu
firefox-3.6
Est différent de firefox3.6.
Quand tu passes ta commande passes tu la bonne ? -
apt-cache search toto = permet de lister les paquets installés ou pas dont le nom toto est contenu dans le nom du paquet !
probablement rien, car la commande que tu utilises ne certifie en rien que les paquets sont vraiment installés !
Je pense que tu t'est trompé. Il s'agit du paquet firefox-3.6 et non du paquet firefox3.6. Normalement si tu fait :
apt-get remove firefox-3.6
ça devrait fonctionner. Ou mieux si tu veut virer les fichier de configurationapt-get remove --purge firefox-3.6
Ensuite tu fait un petit nettoyage en faisant :apt-get autoremove
Et pour le réinstaller, tu saisie :apt-get install firefox-3.6
Note: Pour vérifier si firefox est installé tu fait :whereis firefox-3.6
Ouapt-cache policy firefox-3.6
Pour apt-cache search firefox c'est la réponse de bob031 -
oui mais le probleme est que quand j'ai desinstaller firefox ... je peut quand meme le lancer ... et ca me lance un firefox3.6 ou plus ... pourquoi sachant que j'ai tout desinstaller .
A mon avis firefox3.6 c'est le nom de ton lanceur et non le nom de la commande, essaye de faire :
S'il il est désinstaller et que firefox se lance quand même, clique sur Aide dans le menu de firefox puis cliques sur A propos de Mozilla Firefox -
bon alors ... quand je fait toute les commande dite plus haut par julien .. il me dit qu'il n'est pas installer .. que aucun firefox n'est installer ... or je peut le lancer ... d'ou ca pourrait venir .
Dans ce cas, ça peut-être que tu as téléchargé firefox sur le site de mozilla et que tu ait fait un lanceur sur le script shell de lancement. Regarde dans les propriétés du lanceurs et regarde la commande. En tout état de cause, tu peut faire cohabité plusieurs firefox. Il suffit simplement de télécharger le paquet firefox-3.6 ensuite tu crée un lanceur avec la commande firefox-3.6 . N'oublie pas également de mettre la nouvelle version dans Système -> Application préférées, de sélectionner personnaliser dans la liste déroulante. Puis tu saisie dans commande firefox-3.6.
ModérateurBonjour,
Sous ta distribution, serai-il possible que Firefox existe sous un autre nom que Firefox ? Je pense particulièrement à Iceweasel. Tu devrais aussi ouvrir les propriétés de ton raccourci Firefox (par clic droit) pour voir vers où ca pointe et agir en conséquence.
