Probleme avec nero 7 premium
Bonjour,pourait on m'aider pour graver 1 dvd de donnees car avant j'y arriver mais maintenant ca ne marche plus voici le rapport;
Windows XP 5.1
IA32
WinAspi: -
NT-SPTI used
Nero Version: 7.11.10.0
Internal Version: 7, 11, 10, 0
(Nero Express)
Recorder: <ATAPI DVD W DH16W1P> Version: LA11 - HA 1 TA 0 - 7.11.10.0
Adapter driver: <IDE> HA 1
Drive buffer : 2048kB
Bus Type : default
CD-ROM: <ATAPI DVD W DH16W1P >Version: LA11 - HA 1 TA 0 - 7.11.10.0
=== Scsi-Device-Map ===
: ST3320820AS 3.AA nvstor32 Port 2 ID 0 DMA: Off
=== CDRom-Device-Map ===
ATAPI DVD W DH16W1P E: CdRom0
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
BUFE : 0
Physical memory : 1022MB (1047368kB)
Free physical memory: 378MB (387268kB)
Memory in use : 63 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
28.4.2009
Compilation ISO
16:33:02 #1 Text 0 File SCSIPTICommands.cpp, Line 450
LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
16:33:02 #2 Text 0 File Isodoc.cpp, Line 6711
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
16:33:02 #3 ISO9660GEN -11 File Geniso.cpp, Line 3350
First writeable address = 0 (0x00000000)
16:33:02 #4 Text 0 File Burncd.cpp, Line 3500
Turn on Disc-At-Once, using DVD media
16:33:34 #5 ISO9660GEN -11 File Geniso.cpp, Line 3350
16:33:34 #6 Text 0 File FilesystemSettingsValidator.cpp, Line 142
FS Settings: using validator 'CUDFSettingsValidatorDVD'
ParamMode = 'automatic', changing UDF partition type from 'physical' to 'physical'
Changing UDF revision from '1.02' to '1.02'
16:33:36 #7 Text 0 File DlgWaitCD.cpp, Line 307
Last possible write address on media: 2295103 (510:01.28, 4482MB)
Last address to be written: 2151615 (478:08.15, 4202MB)
16:33:36 #8 Text 0 File DlgWaitCD.cpp, Line 319
Write in overburning mode: NO (enabled: CD)
16:33:36 #9 Text 0 File DlgWaitCD.cpp, Line 2988
Recorder: ATAPI DVD W DH16W1P, Media type: DVD+R
Disc Manufacturer ID: <MCC>, Media Type ID: <004>, Product revision number: 0
Disc Application Code: 0, Extended Information Indicators: 7
16:33:36 #10 Text 0 File DlgWaitCD.cpp, Line 493
>>> Protocol of DlgWaitCD activities: <<<
Insert empty disc to write to.
(Medium in drive: Inconnu. Medium required by compilation: DVD R/RW; DVD DL.)
16:33:36 #11 Text 0 File ThreadedTransferInterface.cpp, Line 778
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 2151616 (2151616) = #2151616/478:8.16
relocatable, disc pos for caching/writing not required/ required
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2151616 blocks [E: ATAPI DVD W DH16W1P]
16:33:37 #12 Text 0 File ThreadedTransferInterface.cpp, Line 979
Prepare [E: ATAPI DVD W DH16W1P] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1: Idx 0 Idx 1 Next Trk
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4406509568, ISRC ""
DAO layout:
___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 1 | 0x41 | 2151616 | 0 | 0x00
2151616 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
16:33:37 #13 Text 0 File SCSIPTICommands.cpp, Line 240
SPTILockVolume - completed successfully for FSCTL_LOCK_VOLUME
16:33:37 #14 Text 0 File Burncd.cpp, Line 4286
Caching options: cache CDRom or Network-Yes, small files-No (<64KB)
16:33:37 #15 Phase 24 File dlgbrnst.cpp, Line 1767
Caching of files started
16:33:37 #16 Text 0 File Burncd.cpp, Line 4405
Cache writing successful.
16:33:37 #17 Phase 25 File dlgbrnst.cpp, Line 1767
Caching of files completed
16:33:37 #18 Phase 36 File dlgbrnst.cpp, Line 1767
Burn process started at 16x (22 160 Ko/s)
16:33:37 #19 Text 0 File ThreadedTransferInterface.cpp, Line 2726
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
16:33:37 #20 Text 0 File Cdrdrv.cpp, Line 10161
---- Disc Structure: Physical Format Information (00h) ----
Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD+R (10), Part Version: 1.0x (1)
Disc Size: 120 mm, Maximum Transfer Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 26053F h
Data in Burst Cutting Area (BCA) does not exist
Disc Application Code: 0 / 0 h
Extended Information indicators: 7 h
Disc Manufacturer ID: MCC.....
Media type ID: 004
Number of Physical format information bytes in use in ADIP up to byte 63: 56
Media Specific [16..783]:
00 00 07 4D 43 43 00 00 - 00 00 00 30 30 34 00 38 ...MCC.....004.8
23 54 37 12 02 54 6C 02 - 92 5F 15 15 0B 0B 08 08 #T7..Tl.._......
01 19 1B 0C 0C 0C 0D 01 - 00 00 00 00 00 00 00 00 ................
01 00 38 38 02 2C 5A 1A - 05 2E 23 10 04 1E 1D 01 ..88.,Z...#.....
00 00 02 2C 5A 1A 05 2E - 23 10 04 1E 1D 01 00 00 ...,Z...#.......
02 00 54 70 02 30 63 3C - 24 14 0C 0C 01 20 00 00 ..Tp.0c<$.......
00 00 02 40 66 42 24 14 - 0C 0C 01 20 00 00 00 2B ...@fB$........+
03 00 54 DF 02 30 63 3C - 24 14 0C 0C 01 20 00 00 ..T..0c<$.......
00 00 02 75 5E 58 24 14 - 0A 0A 01 20 00 00 00 59 ...u^X$........Y
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
16:33:37 #21 SPTI -1066 File SCSIPassThrough.cpp, Line 181
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1066)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x24
Sense Qual: 0x00
CDB Data: 0xDF 00 0F 00 00 01 00 00 00 00 00 00
Sense Area: 0x70 00 05 00 00 00 00 0A 00 00 00 00 24
Buffer x0a829340: Len x80
16:33:37 #22 SPTI -1066 File SCSIPassThrough.cpp, Line 181
Sense Code: 0x24
Sense Qual: 0x00
16:33:37 #23 Text 0 File DVDPlusRW.cpp, Line 675
Start write address at LBA 0
DVD high compatibility mode: Yes
16:33:37 #24 Text 0 File ThreadedTransfer.cpp, Line 268
Pipe memory size 83836800
16:34:38 #25 SPTI -1106 File SCSIPassThrough.cpp, Line 181
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1106)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x73
Sense Qual: 0x03
CDB Data: 0x2A 00 00 00 00 00 00 00 20 00 00 00
Sense Area: 0x70 00 03 00 00 00 00 0A 00 00 00 00 73 03
Buffer x190b0040: Len x10000
0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
16:34:38 #26 CDR -1106 File Writer.cpp, Line 306
Power calibration error
16:34:41 #27 Phase 127 File dlgbrnst.cpp, Line 1767
Generating DVD high compatibility borders
16:34:41 #28 Text 0 File DVDPlusRW.cpp, Line 935
EndDAO: Last written address 0
16:34:41 #29 Phase 129 File dlgbrnst.cpp, Line 1767
Generating DVD borders completed successfully
16:34:42 #30 SPTI -1066 File SCSIPassThrough.cpp, Line 181
Sense Code: 0x24
Sense Qual: 0x00
16:34:42 #31 SPTI -1066 File SCSIPassThrough.cpp, Line 181
Sense Code: 0x24
Sense Qual: 0x00
16:34:42 #32 Phase 38 File dlgbrnst.cpp, Line 1767
Burn process failed at 16x (22 160 Ko/s)
16:34:42 #33 Text 0 File SCSIPTICommands.cpp, Line 287
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
16:34:43 #34 Text 0 File Cdrdrv.cpp, Line 11411
DriveLocker: UnLockVolume completed
16:34:43 #35 Text 0 File SCSIPTICommands.cpp, Line 450
UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
Existing drivers:
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon
Configuration: Windows Vista
Internet Explorer 8.0
  1. bonsoir
    oui,c'est nomal que tu ne puisse graver vista ne fait pas bon menage avec nero,seulement a partir de la version 8
    telecharge l'equivalent gratuit simple et performant rien de plus simple ici:https://cdburnerxp-32-bit.fr.softonic.com ne t'inquiete pas du xp qui est dedans il fonctionne tres bien sous vista c'est celui que j'ai bon gravage A+
    1. bonsoir et merci pour la reponse mais je vien d'essayer et ca ne marche pas non plus j'ai le meme message d'erreur qu' avec copy to dvd"power calibration area error 0x037303.
