Configuerer Pro FTP
Bonsoir.
J'ai instaler ProFTP mais je n'arrive pas a le configurer.
Je ne comprend pas pourquoi.
Jai mais ca dans mon .conf peut on me dire pourquoi:
Je n'ais pas le droit d'ecrasser mes fichier...
et pourquoi dans mes sous dossier je ne peus rien faire
# This is a basic ProFTPD configuration file (rename it to
# 'proftpd.conf' for actual use.  It establishes a single server
# and a single anonymous login.  It assumes that you have a user/group
# "nobody" and "ftp" for normal operation and anon.
ServerName			"FTP AS²"
ServerType			standalone
DefaultServer			on
# Port 21 is the standard FTP port.
Port				21
# Umask 022 is a good standard umask to prevent new dirs and files
# from being group and world writable.
Umask				022
# To prevent DoS attacks, set the maximum number of child processes
# to 30.  If you need to allow more than 30 concurrent connections
# at once, simply increase this value.  Note that this ONLY works
# in standalone mode, in inetd mode you should use an inetd server
# that allows you to limit maximum number of processes per service
# (such as xinetd)
MaxInstances			30
# Set the user and group that the server normally runs at.
User				nobody
Group				nogroup
UserPassword nobody Qn4KIQykF7uh6
DefaultChdir /home/www/
# Normally, we want files to be overwriteable.
<Directory /home/www/*>
  AllowOverwrite		on
  <Limit ALL>
  AllowUser nobody
  </limit>
</Directory>
# A basic anonymous configuration, no upload directories.
#<Anonymous ~nobody>
#  User				nobody
#  Group				nogroup
  # We want clients to be able to login with "anonymous" as well as "ftp"
#  UserAlias			anonymous nobody
#  RequireValidShell       no
  # Limit the maximum number of anonymous logins
#  MaxClients			10
  # We want 'welcome.msg' displayed at login, and '.message' displayed
  # in each newly chdired directory.
#  DisplayLogin			welcome.msg
#  DisplayFirstChdir		.message
  # Limit WRITE everywhere in the anonymous chroot
#</Anonymous>
  1. J'ai deja vu cette page....
    Ba en fait tous les utilisateurs on les droits de toute faire .....mais il ne peuvent pas quand les fichiers ont etait mis dans le repertoir du ftp a partir du pc....
    1. Bon merci mais j'ai fais un resset total et j'ai instalé gproftp...c'est tres partique
      Par contre comment faire pour que des dossier et des fichier que l'on a mit directement dans le ftp par la machine soit modifiable reerisible et chmodable a tout user du ftp ?
        AllowOverwrite		on
        C'est pas plutôt yes ?
        Bonne chance
