Probleme graveur DVD ide
Bonjour à tous,
Voila, je suis en train d'instaler un graveur dvd sur mon pc en ide mais lorsque je veut l'utiliser, il me met des messages d'erreurs concernant un driver sg alors kque normallement il me semble qu'il devrait utiliser l'emulation ide-scsi....
J'avoue je suis un peu perdu.
Merci par avance de vos réponses.
Voici donc le message d'erreur:
[root@localhost shell]# cdrecord -v dev=1,1,0 driver=mmc_mdvd image.iso
cdrecord: No write mode specified.
cdrecord: Asuming -tao mode.
cdrecord: Future versions of cdrecord may have different drive dependent defaults.
cdrecord: Continuing in 5 seconds...
Cdrecord-Clone 2.01a27-dvd (i686-pc-linux-gnu) Copyright (C) 1995-2004 Jörg Schilling
Note: This version is an unofficial (modified) version with DVD support
Note: and therefore may have bugs that are not present in the original.
Note: Please send bug reports or support requests to <warly@mandrakesoft.com>.
Note: The author of cdrecord should not be bothered with problems in this version.
TOC Type: 1 = CD-ROM
scsidev: '1,1,0'
scsibus: 1 target: 1 lun: 0
cdrecord: No such file or directory. Cannot open '/dev/sg*'. Cannot open SCSI driver.
cdrecord: For possible targets try 'cdrecord -scanbus'. Make sure you are root.
cdrecord: For possible transport specifiers try 'cdrecord dev=help'.
sachant que si je fait le scanbus, il me donne ca:
[root@localhost shell]# cdrecord -scanbus
scsidev: 'ATA'
devname: 'ATA'
scsibus: -2 target: -2 lun: -2
Warning: Using badly designed ATAPI via /dev/hd* interface.
Linux sg driver version: 3.5.27
Using libscg version 'schily-0.8'.
cdrecord: Warning: using inofficial libscg transport code version (schily - Red Hat-scsi-linux-sg.c-1.80-RH '@(#)scsi-linux-sg.c 1.80 04/03/08 Copyright 1997 J. Schilling').
scsibus1:
1,0,0 100) 'SAMSUNG ' 'CD-ROM SC-148A ' 'B403' Removable CD-ROM
1,1,0 101) '_NEC ' 'DVD+RW ND-3100AD' '107E' Removable CD-ROM
1,2,0 102) *
1,3,0 103) *
1,4,0 104) *
1,5,0 105) *
1,6,0 106) *
1,7,0 107) *
Donc je ne vois pas ou pourais se trouver l'erreur.
Merci -
Bonjours,
Peux-tu copier les messages en question?
a+
eric
