Reprogram a superior 1:1 remote control problem!!!
Hello,
I found an old universal remote at a friend's place, it's a Superior 1:1
I searched online and they all say that an external box needs to be connected to a PC
to reprogram it, but it's not provided. Is this reserved for professionals?
I thought I could program it via the remote, is that really not possible?
Who has this kind of box?
Thanks for your responses, I'm really annoyed, programmed obsolescence is lurking ;)
sylvain.v
Configuration: Windows / Firefox 58.0
1 answer
  1. Contributor
    Good evening,
    There are several models from this brand... so which one is yours?
    It should normally be ready for standard TV orders...
    Programming with a PC is done using a USB cable... it's up to you to know the right codes to get your TV or home theater or other device to work.
    You should have a manual with it... or the manufacturer's website that allows you to download it...
    But we don’t have the answer for all the TVs in the world... with all the different types of remote controls that exist.
