Lost manual and remote code URC22D-8
MARGUERITE8989
jmp59 Posted messages 29288 Registration date Status Contributeur Last intervention -
Hello, I lost my manual for the URC22D-8A remote control and I would like to know if someone could give me the codes for a Goldstar TV. Thank you in advance, as I am stuck and it's urgent.
The brand of the TV is not enough, and it's generally secondary: because most universal remotes have a search function that allows you to find the code corresponding to the TV.
An example of codes, for your TV if your remote is a Thomson:
GOLDSTAR 003 009 012 019 051 084 093 129 131 169 171
If, as is probably the case, it's another brand, please indicate that brand and its model.
thank you
thank you
http://lolograzzini.free.fr/files/page8.gif
It's for the remote control URC22B but it should also be valid for yours.
To err is human, to persist is diabolical.
