Difference between USB Key and USB Flash Drive?
Solved
ßokchips Posted messages 169 Status Membre -
 cicisse -
Hello,
I know it's a silly question, but I would like to know what the difference is between a regular USB key and a USB flash drive? Do they work the same way as the regular ones?
Configuration: Windows Vista Mozilla 1.9.0.6
papy-ion Posted messages 4130 Status Membre 1 013
It's just the name: USB flash drive (in English) = clé usb (in French) see the photos at these links.
For a flash drive: https://en.wikipedia.org/wiki/USB_flash_drive
for a USB drive: https://fr.wikipedia.org/wiki/Cle_usb
I think this will answer your question better than a long speech.
Have a good evening.
104
cicisse
Thank you for the explanation. I also wanted to know the difference but I hadn't asked the question.
