Issue with setting the price on the marketplace
Solved
Hello, I can't set the price on my marketplace listing to sell my vehicle. You can only enter a single digit after which it jumps and the listing won't be valid.
Do you have an answer to that?
Configuration: iPhone / Safari 14.0.1
1 answer
  1. I have the solution: copy the total and paste it where it doesn't work.
    1. I removed the ad and redid it using the trick of going back before the € symbol, and there I was able to set the price.
    2. Thank you, it worked. Have a good day.
