Issue with the Realtek RTL8723BE Wireless LAN 802.11n PCI-E NIC.
Solved
Hello,
Since the end of June or beginning of July, I have been having a problem with my wifi driver.
It appears hidden in the device manager with error code 45, which means I have no access to wifi, which is frustrating with a laptop.
In terms of additional information I can provide to help understand the problem:
-The issue appears and disappears without any warning during restarts.
-The factory reset of Windows and the reinstallation via USB stick did not resolve the problem.
-Installing drivers, as well as updates, did not solve the issue.
-The only modification made to the computer was installing a RAM stick in December 2019.
-Ethernet still works, as does Bluetooth.
-The computer I use is an Asus R541U, purchased five years ago, so it’s out of warranty.
-The computer has not suffered any blows, has never fallen, and has never been submerged.
Thank you in advance for your responses, and if anyone has an explanation for this problem, I would be happy to know.
PS: Yes, I’ve heard that it's a problematic wifi card; I learned this while researching in the past few days.
  1. Contributor
    Hello,
    What version of Windows is it..?? to get the appropriate drivers.
    The update via Windows Update doesn't necessarily update the Wi-Fi driver.. Indeed.
    This topic has already been successfully addressed here... https://forums.commentcamarche.net/forum/affich-36107881-carte-realtek-rtl8723be-wireless-lan-802-11n-pci-e-nic
    You have to search a bit..
    1. Thank you, this is Windows 10 64-bit, and for the given link, well, all I have to say is thank you, but I've already tried it without success, unfortunately.
