Problem: 2 jack ports on the PC for a single jack plug with my headset.
Solved
Hello, unfortunately I have a problem with my PC: on my PC there is 1 jack port for the microphone and another jack port for sound, but I have a headset with only 1 jack plug, so how can I combine 2 jack ports into one plug on my PC?
Thank you for your response!
(Sorry for the spelling mistakes)
Moderator
Hello,
You need an adapter like: https://www.pearl.fr/article/KT7327/adaptateur-micro-casque-pour-prises-audio-micro
Best regards
a stranger is a friend we haven't met yet. -
Hello,
I have the same problem as you, but I just wanted to know if, before you had the adapter (I don’t know if you have it), and even if you do, if your PC detected your headset or the microphone on your headset. -
You actually need to plug your headset's microphone into the jack with the microphone logo on your PC.
Sorry, but it's really urgent :/-
@walfaWell, I did it but I can barely be heard and the headset and the microphone still aren't detected :/
I can't take it anymore ???????????? -
@GROSPROBLEME_1994For the sound, if you're using Discord, you can increase your microphone volume directly in the settings. Otherwise, for the headset, click on the speaker icon at the bottom right of your screen, and there should normally be an arrow like this: > that points upward. Click on it, and then you can choose the name of your headset. Sorry for the mistakes.
Otherwise, I don’t see how to do it. -
@walfaOh, it's strange, my computer doesn't detect my microphone or my headset, but Discord works perfectly. However, since my computer doesn't detect my headset, I don't think I can increase my voice volume.
