Neoxeo Power Bank 4400 mAh Issues
Solved
Drayx Posted messages 139 Status Member -
Hello,
I just bought this external battery this afternoon, but I think it has a defect. There are normally 4 blue LEDs to indicate the remaining battery level. I charged it late this afternoon and tonight, and out of the 4 LEDs, only 2 are lit. I feel like I can't charge it completely.
I'm going to leave it overnight and see if it charges.
What do you think? Should I try to fully discharge it or just leave it overnight? Or should I change it directly tomorrow at Fnac?
1 answer
  1. Judge_DT Posted messages 27651 Registration date   Status Moderator Last intervention   10 013
    Hi,
    4400mAh is more than many smartphones in capacity, smartphones without "fast" charging usually take between 1 to 2 hours to charge.
    In this case, since the battery is larger, it might take longer... Although, more than 4 hours would be very surprising. What type of device or charging adapter are you using to recharge it?
    ~ To know how to listen is to possess, besides one's own, the brains of others... said Leonardo da Vinci.
    1. Drayx Posted messages 139 Status Member 10
      Hi, I had it charging on the charger of my Moto 360 but it turns out it delivers less than a normal charger, so I just put it on my phone charger to see if there's a difference.
