My SAMSUNG TV turns off and on again.
Solved
Bobmarley01
Charly -
Charly -
Hello,
My SAMSUNG TV, model IN32A450CID, turns off and on when it decides to!! It's not in a cyclical pattern, and it's not the standby mode that is activated, because in that case, it would be easy for me to simply turn the TV back on and change the settings! However, here the light that indicates the TV is off starts to blink barely perceptibly every 5 to 10 seconds once the Power button is activated and remains off!! I've heard about a chip that, after a certain number of years, intentionally causes the TV to "bug" in order to force people who own that same TV to buy another one! (Question of business, of course...) If that's the case, I would like to know if anyone has knowledge of the exact location of this chip in this kind of TV model and whether removing it could "fix" my TV, or simply tell me how I could remove any part to force the TV to turn on when plugged into a power source. In short, I want the TV to turn on without prompting, and to light up at the very moment power flows through the plugged-in cable!!
- 1
- 2
Next
Resolution: Access the hidden menu: Info, Menu, Mute, Power
- Select menu "8-adjust"
- Select D-Watchdog ->"OFF"
- Power to exit!
That should solve the problem!-
Hello,
do you have the solution for another SAMSUNG model because I can't find menu 8 -adjust and consequently D-Watchdog either.
Thanks in advance, the model which I can't recall the reference (32....) is a model from 2010.
P.S.: I can access the hidden menu with the first manipulation.
Thanks in advance
Best regards
solodream14 -
- 1
- 2
Next
